Australian Belly Tank
grumm441
and the motor and gearbox is resting in place , without cutting up the car. and using the Greeck Coupler that Sid sent
Now if I still had a photobucket account I could send pictures
grumm441
kiwi belly tank
Hell yeah, that fits good Mate!
grumm441
I'm going to shorten the coupling a bit and move the engine back some more
https://photos.app.goo.gl/PYd6KJZO7JTpqHZ72
These photos don't work for me -- shall I throw in another bucket of coal?
salt27
Grumm, looks like great progress.   :cheers:
Is there a chance for 2018?
It seemed like there was quite a bit to take care of.
Thanks for the tour, Don
Dr Goggles
Don, if he could get any decent help it'd be easy :dhorse:
Decent help is boring.
Raunchy help gets results.
Dr Goggles
See that's what I reckon but the last time I turned up nude at the Colonel's he got all funny.
grumm441
Quote from: Dr Goggles on November 08, 2017, 09:09:49 PM
I had run out of gloves
Stan, are you clicking on the link. Although they're not that interesting
kiwi belly tank
Quote from: grumm441 on November 08, 2017, 01:00:08 PM
That chassis plate sure is a thick mutha! Are you going to be able to pull the trans without pulling engine or diff?
grumm441
Quote from: kiwi belly tank on November 10, 2017, 08:38:51 AM
No Is the answer
the gearbox isn,t or shouldn't be a problem
the issue is always the diff. If we wand to change the final drive ratio, we have to pull the motor
I'm working on this.
And Stan, I'm might have an issue with the shared drive that the pics are in. I'm looking into it
kiwi belly tank
I agree the trans is probably bullet proof, I was thinking more if you had a clutch issue. You could cut that plate down both sides & make it a bolt in.
What have you had fail in the 10 bolt?
Crack test used gears before you run them & there's a curdle available for the 7.5 10 bolt that prevents housing flex & supports the carrier caps, worth the money on these little diff's.
Dr Goggles
Nothing has failed on the 7.5's we had a pinion nut come loose on it once but nothing has let go. The only reason to go in there is ratio changes.
We now put a spot weld our pinion nuts.
I have made my 7.5 rear axle so that I can pull it out the back of the car. I change complete axle housings, to change gear ratios using the same axles backing plates and brake drums--using a quick disconnect fitting in the brake line makes the brake bleeding much faster with a lot less fluid lost.
