azgearhed
Like I said-lemme know if I can help with something -I'd like to repay the help you gave us. :cheers:
BC Racing 1979 Z-28
AA/CBGC Record 251.802 Speed Week 2012
AA/CBGALT Record 255.382 Speed Week 2013
AA/CBGC Record 226.104 El Mirage Sept 2015
AA/CBFALT Record 227.954 El Mirage June 2016
AA/CBGC Record 267.878 Speed Week 2018
AA/CBGALT Record 236.458 El Mirage Nov 2016
It's a lot of work to have fun...
Thanks Tim,
No debt--- no obligation-- I just hope you don't hold it against me for any part that I may have played in your addiction---  lol   8-)  I will give you a call  Mon. AM!!!!!!!
 a very good day
Francis drove up from Oro Grande and took the lead in his and Frankies efforts with the switch panel  and wiring the systems
Andy helped me at the rear of the car with this darn pilot chute launcher  :-P  this thing could be dangerous when you have to generate around 75-90 # of force to depress the darn spring---look out, stay away and be careful, and build in some with some safety measures. :-P
Jon
Those chutes do pack some pressure, i made a loading pin for mine to make it easier to pack.
A couple of people have asked about my chutes lately.
Think I'm running the same sort of pilots as you (Stroud), will chuck a couple of pics up in my thread.
jon
Underhouse Engineering
Thanks Jon I will post some picts of the windlass we built today.
tomorrow we will put the tanks in, and put the eng and tranny back, as well as the frt of the tank.
we can then get on with the final plumbing an wiring.  the FLUIDS distilled water in the eng and cooling.
0-30 Synthetic Motor Oil  in the rear diff
synthetic Mobil 1 motor oil in motor
Synthetic trany oils in th PF and GV  use different stuff
#1355
Francis and Frankie's handy work yesterday
Frankie wired in the GV switch today and built the bracket that secures the cooling water tank
#1356
Marty dropped by this afternoon and repaired the the flexplate ,that I run without a torque converter, by building up the mangled teeth and then truing them with a floppy grinder disk.
Andy took the lead on getting the tanks back in, and finishing  the 7.5 " GM rear axle is now locked down, has not quite 2 qts. of Mobil 1 0w-50w and is now ready to be bled.
#1357
The Spanish Windlass Marty, Andy and I came up with that will let us install the Stroud Pilot chutes---  simple ---sorta MM but  we can load the chutes and they "FIRE" out the pilots  :-o
The cooling system pumps are getting locked down and  final plumbed.
I am starting to install the fuel system up front---tight and tricky to get it all in and working.
Tim should be up tomorrow and the thrash will CONTINUE!!!!!!!!!!!!
Frankie7799
You guys got quite a bit done after I left, sweet. Did you wind up having to drill holes in the body to get the tank straps fastened or did you you have enough room tilting the two outer tanks?
nope---tilt the two side tanks and jam the radiator in a box in---lol
Ron Gibson
Sparky
Don't know if you run any "wetter". My purple says "NOT" to run distilled water. I don't have any idea of why, but that is what the label says. Maybe some one more informed than me can explain.
Ron
Finallygotit
From Wikipedia....
QuoteDistilled water is preferable to tap water for use in automotive cooling systems. The minerals and ions typically found in tap water can be corrosive to internal engine components, and can cause a more rapid depletion of the anti-corrosion additives found in most antifreeze formulations.
Dan
Tucson, AZ
lsrjunkie
Looking good guys!  :cheers: I'll be tracking you guys down next week to check this beast out in person! Keep up the thrash!!
#1363
do not run any wetter---I run distilled so that I do not have to worry about mineral build up which is almost like ceramic as for as stopping heat transfer.
01 Tim Cox came up this AM and we got to work he modified the starter so that we can get it lump in the car  :-o
02 the chutes are almost done
03  the drive train and required safety items are almost all finished
#1364
well the eng and tank bay is starting to get crowded
