Quote from: SPARKY on August 30, 2013, 03:36:21 PM
:-D  hate to disappoint you guys---but by throwing my left leg over the side and sticking my right knee is the lower left side of the canopy I can now get out -....
...an here I thought I'd get a call in the morning from Linda asking if I knew where you took off to  :-)
Quote from: SPARKY on August 30, 2013, 03:36:21 PM.....
ECU
ECU data logging start
Quick data
Quick data logging start
Can you put the ECU and the Quick data on/off on the same switch and also do the same with 'start logging' functions for both.  That would be 2 less switches to find room for.
How about the fuel?  Is it mechanical pump with a fuel shut-off or electric with a switch and auto roll-over switch which I don't want you to ever try using on the course?
mechanical pump, mechanical shut off
  Sum all of the data logging that I have  require a secondary "signal" to start logging either time, throttle position, rpm or a separate  switch
#1277
WayneO  :-o WF---it is breaking my heart to not see the the first runs on the salt of Rob's and Marlo's new 'Liners  but I want to run my  car worse----I have decided to stay home and work on my car---there is still a TON that needs to be done--but slowly  the loose ends are getting tied down---the binge-engineering is almost all done!!!!!!!!!!!
"The fallacy lies in the execution" Vince Lombardi---GB Packers  1964
PS  Wow  I must have been ?????????? I wrote facility instead of fallacy--- after rereading this this morning  I decided to look the word up again, it just didn't "read" right---turns out just about means the opposite of each other--- muddled sr.minds
Quote from: SPARKY on August 30, 2013, 09:32:39 PM
I'll call you tomorrow (sat.).  You could use switches with 2 poles to control the separate start signals via one switch if needed.  I'd also think that one switch could control the power to both loggers.  I'd think you would want to start logging on both at the same time to help somewhat with correlating them time-wise.
I have a feeling that sooner or later you will end up with one device to do the logging.  I tend to use the rpm track (easy to see the shift points) and the TPS most of the time to tell me where and what the driver was doing then add or subtract the other channels.  Looking at them all (16) at once is too confusing.  With the logworks you can look at any combination and it also gives time across the bottom.
Sum, you may be right but the QuickData has EGTs and several temp and pressure probes---
right now I have decided to use the QD for stuff be fore the intake inlet and the ECU Data logging for the eng functions
#1280
A pretty good day in the shop-- and a trip to Ace Hardware, Home Depot and O'Rileys.  Chasing drawer pulls and cable stops for the throttle cables and chute cables and some 10-32 screws for the coil isolator pads.  I have just about gotten all of the "before instillation" mounting done on all the cables and water lines.
We are now almost to the point where we make the eng bay sheet metal pull the eng,finish welding the new diagonals,seal the bulk head on both sides, and weld a bunch of nuts we will not be able to get to, and mount the sheet metal.
Then get the eng. finalized and install wire and plumb.
It never stops amazing me that I can spend several busy hours in the shop and to have no more that a few tapped holes in a now hard mounted bracket to show for it.
This thing continues to evolve in my pea brain:
In honor of the F 105 "Wild Weasels"  from which my bomb bay tank came from, I will do my nose with "nose art." I think I will then put the name of "Ms. LIBERTY" on it in honor of all who have and are fighting  for our liberties, be those battles foreign or domestic, in or out of uniform.
doug odom
Yes Sparky, That last 10% of a race car build takes 10 times longer than planned.
Doug Odom in Big Ditch
Doug Odom in big ditch
Jon
Sounds like its coming together well Sparky, list must be getting shorter.
Do you want me to send new batteries for your camera :)
Cheers
jon
Underhouse Engineering
Jon,  I am just about through will pulling the two 1/4" steel lines one for vac. and one for boost, and I nearly have the fire bottle and chute releases--I have one more bracket to relocate and almost through with the throttle cable.  I did hunt down the upload cable though and do know where the camera is   :-D
Jon
more
last 2
Jon
Thanks Sparky.
Got a fair bit happening.
Like the shape of the new front hoop, not a big fan of the S bend shapes, they're probably plenty strong.
Cheers
jon
Are there veins inside the scoop?
#1289
Veins o
are for mainlining, vanes are for turning  ---
Dr. F-- knowing you I know that was a test to see how well or how fast I wake up in the morning ??  not yet this thing is on purpose huge inside  I am planning on putting a  splitter inside to keep air from going straight across the top of the carb.
