kiwi belly tank
Yeah, that's usually pretty handy.
You planning on hanging the "hair dryer" back on there?
Sid,  I have some, what I hope to be minor helmet venting issues, to solve.  I then plan to change the axle & gearing for to more suitable for El M, install the intercooler, and turbos for more rear end weight but run NA at El M until we get the car sorted out then-- go play with the turbos at B'Ville.
kiwi belly tank
I have a new helmet blower sitting on the shelf that I'm not using. I would gladly donate it to your cause if you can use it.
Thanks Sid for your offer-- Andy has one also  let us see if we can use his system and his helmet  we may be calling
#1564
Quote from: Rex Schimmer on November 12, 2013, 02:03:08 PM.... I do not know what the SCTA/Goodyear speed limit is on the new "Top Fuel" tire, 4 x 17 Goodyear part number  808-130-089 which is about an inch wider but still is made to fit a 17 x 2.5 wheel.... Rex
I can't find that tire by that part number using Google.  If you go to the Goodyear site here....
http://www.racegoodyear.com/tires/pdf/Drag_010313.pdf
....is it the 2904 on page 3 of that document?
um,
Yes it is the 2904 which is the front tire that Top Fuel has been running for the last 2-3 years. As I said I am not sure what the speed rating is, I do know that the older tire had a life of about 4-6 seconds on the rim at 275 mph.
kiwi belly tank
Quote from: Rex Schimmer on November 14, 2013, 12:06:46 PM
um,
That might not be long enough for Sparky! :roll:
Frankie7799
Sum, yes the 2904 is the 17 x 4 inch Frontrunner the TF cars are using. Back in about '06 they were finding with the narrower 3 inch Frontrunner at 310+ the tires were starting to blister and chunk rubber. Since moving to the 4 inch tire and creating a larger contact patch they have resolved the problem
Quote from: Frankie7799 on November 14, 2013, 03:35:17 PM
Well we are on to plan "B"  the vent system on Andy's helmet will not clear our "shoulder pads" but his G force helmet works much better with its "visor opening" on to working on using it.
Henderson North Carolina  ---does anyone live near there?
Captthundarr
There are some ECTA guys that are fairly close. I'm about 3.5hrs one way.
Thanks Cap'n T  going another way thanks
gkabbt
Quote from: SPARKY on November 17, 2013, 05:56:45 PM
Sparky, If you decide on the Henderson, NC thing let me know as I'm only about 1 hour away.
Can't help you this week as my wife and I are on a Caribbean cruise. We get back home next Monday afternoon and will be available then.
Gregg
Buickguy3
#1574
    Is it one of those cruises where you sail out and they tow you home? Just kidding.
   :evil: Doug  :cheers: :cheers: :cheers:
                   [America]
