Buddy---I am with you on this. These two pumps should be able to cycle this 22 gallon tank in less than a minute --I think  :-P
There should be a fairly strong down current created in there.   We plan to warm the eng. with only the radiator water.  Then pump the front mounted radiator in a box full of water; then top offl the rear tank with mostly ice---we will depend on the liquid from the front box and the intercooler to cycle and of course the liquid volume will go up as the ice melts.
#1186
Quote from: robfrey on July 13, 2013, 07:09:31 PM
I would not worry too much about that strainer. It may restrict flow. I have never known anybody to have a problem with ice going through the pump. Most of our gang use the Rule submersible pumps and they just seem to pass the smaller chunks through. The nice thing is that ice always floats. As long as you are sucking from bottom of tank, you should be getting cold water and not much ice.
Good info, I'm just starting on the ice water tank for Hooley's car.  I have two of the Rule 1100 pumps that I'll be putting in the tank for the two intercoolers.  Which pumps did you use?
I finished the radiator in a box (based on Sparky's design mostly) yesterday and hooked one of the 1100 pumps to it and it pushed 15 gallons a minute through the box.  It is rated at about 18 gallons a minute with no head.  Hooley has a Meziere pump that we will use for the rad-in-a-box when it is in the car,
Quote from: SPARKY on July 14, 2013, 05:36:31 AM
Rob don't those rule pumps have built in strainers?  ...
They do...
... but I think I'll also try and protect them some also with some screening.
Sparky the tank looks good  :-),
It also looks great to see a post done by S U M N E R.
One of the kids came back to the family.
Quote from: Freud on July 14, 2013, 07:55:25 AM
That is what happens when you forget to lock the door  :-).  Hope to see you soon,
Dynoroom
We use a 15 gallon tank, half to 3/4 full depending on vinue. We run a screen as we don't use a plastic submersible pump prefering to use a Jabsco remote pump with bronze impeller and housing.
Joey came over for 3 hours hours we are getting closer on the canopy!
38flattie
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Bill;
I think the abrupt angle of the forward edge of your canopy is going to create some serious drag. Why not lean it back at a shallow angle?
Jon
#1194
Looks good Sparky.
It's not only the ice that is a worry, I'm worried about torn bits of bag and other dross that the pump can deal with ending up plugged in the cooler core.
jon
Underhouse Engineering
Neal that is by choice---I am trying to decrease the expected lift at the transition ---by putting more air down the sides and less of it over the hump!
JimL
I really like that look.  It reminds me of some cool old airplanes.
And some of them were real fast!
There were a couple good reasons for it, and it has been used on other applications where glare makes steering, conning, piloting, etc difficult.
Regards, JimL
Quote from: JimL on July 14, 2013, 04:34:25 PM
Regards, JimL
JimL;
Going by a Bf109 canopy, I'd guess it was made that way because it was easier to make and the bullet-proof glass came in flat panels. Even so, the front glass was slanted back.
I still think it would be better to reduce the canopy drag and overcome any lift that may be generated by an aerodynamic canopy elsewhere.
Quote from: manta22 on July 14, 2013, 06:27:37 PM....I still think it would be better to reduce the canopy drag and overcome any lift that may be generated by an aerodynamic canopy elsewhere.
There were a couple reasons for the canopy in that shape.  One is that the glass is bent in one plane and not a compound curve thus something that could be done fairly easily in a home shop.  This also results in better vision as was mentioned above.
I suggested it to Sparky for the reasons above and also that it is a nice teardrop shape and should enter the air pretty well and as Sparky mentioned send some of the air hitting it down the sides of the car.  Time will tell how it works and if it doesn't then Sparky will have another project for next winter  :-).  In relation to the rest of the frontal area it is a fairly small portion of it.  I guess it is just another example of the compromises that have to be made at times  :-),
Sum;
As they say, "The proof is in the pudding." Some small wool tufts taped on the body will reveal all.
