lsrjunkie
#1875
Sparky, its pretty hard to beat an LS with a hairdryer on it. The boys over at hot rod magazine took a junkyard LS, swapped the cam and hung a turbo on it. This was a few years ago, but after they got done horse whipping the hell out of it, the Dodge thing made close to 1000hp with stock guts! Now, I realize they may have exaggerated a bit for the sake of entertainment, but if they were within 15 to 20 percent of that number, that's pretty darned cool in my book.
We will Neil---my wife has a friend down there she went to HS with in Pa -- she wants to visit Suzie.  When we come down to pick up the 4.8 -- I will try to pick up Francis and come down to see you...
Sparky said:
" My car is set up for the fuel pump on the passenger side and the dry sump on the drivers side just opposite of most LS drives.  I hope to plump an LS for down the road this winter."
Sparky, one of the things that I have seen work very well is to have the fuel pump driven from the back of the dry sump pump. Not hard to do and you eliminate an extra belt/pulley/mounting bracket and if the drive belt to the dry sump breaks or pitches the fuel pump stops and kills the engine, hopefully before the crank starts to weld to the bearings.
Just a thought.
Quote from: Rex Schimmer on December 18, 2014, 11:32:36 AM....Sparky, one of the things that I have seen work very well is to have the fuel pump driven from the back of the dry sump pump. Not hard to do and you eliminate an extra belt/pulley/mounting bracket and if the drive belt to the dry sump breaks or pitches the fuel pump stops and kills the engine, hopefully before the crank starts to weld to the bearings.
Just a thought.  Rex
Interesting, thanks.  Do they normally run at the same speed?  As you can see I don't know much about dry sumps and such but have started to study more since I'd be running that configuration if I ever get a new motor for the lakester built and it done  :cry:,
#1879
Rex,  I could do that, my pump has a drive on it-- but I do not like where it would be---under the exhaust.  Francis and I were talking about maybe mounting the dry sump pump in front of the eng. not beside.
Sum yes they are typically at 2 to 1 ratio---lots are driven off the cam.
Ron Gibson
Or you could run a cable as Dynoroom posted on pg 12 of his build.
Ron
#1881
 Well, I got a call from the Goodyear Race tire dist.--- they are closing Phoenix location and moving everything to Las Vegas asked me to come down and pick up my tires---
:dhorse:  Still nothing from Goodyear about the "CORRECT WHEELS" to mount these Front Runners on!!!!!!!!!  I suspect we never will!!!!
The Sadddddddddd--thing  :dhorse:  they are made to mount on motorcycle wheels, and would be perfect for the faster bike guys to put on the front of their bikes---SCTA will not let them because--  :dhorse: Goodyear CALLS them CAR tires.
Bill;
Since Goodyear is closing it's Phoenix facility, are they having any bargain sales?
Neil, I sorta asked--was told they are loading everything on the two trucks and everything goes to their Las Vegas operation.
#1884
Francis came up today-- we messed around with NACA 22115 axel fairings and what will be the new canopy profile..
thanks Neal  You are correct--- it should be the 4 digit 2215
We are looking to put a 0015 on the frt axel we just need to streamline and just put a little down force on the front  about 200-250 at speed up front.
Oh I forgot  :-D I gave myself a Christmas present from Stroud--- an El Mirage sized drag chute the "boys" didn't like my 2 B'ville chutes ---this one will be a different color---NO confusion---will be on the look out for Brown Santa!!!!!!!! would not want to go out the back door.
#1888
Francis came up today and we worked on the Lakester ---lots of NOODLE time for a wing mount. He brought an 11" wing he made out of stiff posterboard. We played with how we might mount it and we played with how we might mount an upper wing if we ever get to that point.  He is really coming along with the canopy and we noodled and measured with that for quite some time.
Chutes:
I received the new Stroud Chute for El Mirage: it is one of his 11' tri-corn Drag models with 45' lines. This will be my secondary chute for El M.
My primary El M will be my 8' ribbon chute with a 15' extension on its 45' lines; I plan on both being deployed.
At B'ville I run the 8' without the extension as my secondary. My primary at B'ville is a 6' ribbon chute that has 60' lines.  I can run these move these back and forth very easily by the way, because of extension and being able to change which tube they a installed in.  The hand sequence movements in the cockpit do not change.  the pilot chute tubes are 3" irrigation pipe and the 6" irrigation pipe the chutes and lines are packed in.
Bill;
Is your 8 foot ribbon chute from an F-5A; a drogue chute?
