kiwi belly tank
If anything gets to run on the salt this year I'll be there. I can't remember what your feathers looked like bitch....I mean Mate! :-D
If they're anything close to an F-105 I'd say yep adoodle!
Well we lucked out  we dusted off the roof air on this thing and it hasn't run in about 15 years-- it creaked, groaned, squealed,  blew dirt then lo and behold it started blowing cold air  :-D  next up is the alarm system
Calling around yesterday trying to get insights about one thing, I think I had a nugget dropped on me about something else --I will be calling a manufacture about that something today,  as to do with valve train stability.
grumm441
Quote from: kiwi belly tank on June 13, 2016, 02:56:27 PM
Have you considered surgery? :evil:
I've had surgery to make both my legs the same length. Although pleased with the results, I still can't drive our lakester
We now have laundry baskets to hang on the tail feathers ---after a run we will hang the laundry basket over the tail fin and we should be good to go when we hook up the tow bar to the frt axle no more having to ride in an un sprung car for 15 miles at B'ville.
Sid---you look'em good
the tail feathers of my nose piece?
kiwi belly tank
Totally different to my 105 stuff, thanks any way Mate.
#2212
Francis came up and we were busy in the shop today finally got the new wheels and tires on Ms Liberty---Thanks Podunk---should be ZERO scrub radius
Jack Gifford
Looks like very low tire-to-ground friction.
Will you also be reducing aero drag with discs on the inboard side of the wheels?
M/T Pontiac hemi guru
eventually we will Jack---we are just now finally getting to run this thing with no visability  issues once wil get it running straight and true we will begin to try to "clean up our act" and "tart up"
tauruck
Beautiful wheels and tires, Sparky :cheers: :cheers: :cheers: :cheers:!!!!!!!!
WOODY@DDLLC
Ms Liberty got a new pair of shoes!  :-o Hope to see her [and you] at the Salt Flats Ball in August!  :cheers: :cheers:
#2217
As we get closer and closer to having a car that WORKS---ie we go through inspection, go down the track, bring it home and have less and less that we feel compelled to change- let alone have to fix
We are getting closer and closer to the tweaks that will clean her up aero wise and for the eyes.
Yesterday I changed the chutes out for B'Vill and the several other small time consuming things.
Dug out my 30" Mickeys---we will not have to change the rear end to lisc. up---to AA  ---  YEAH!!!
if we have a decent track we should be able to run all out on a 3 mile and should be in the 275-300 range on exit if all goes well.
We will have 2 rookie drivers and I need to make a 250+ to lisc back up. Remember by the rules you go down a level every 3 years.
 :cry:  well the best laid plans----
We get to un do what I did yesterday by changing back the chutes!!!!!!
