#2115
Sumner came over today and he had a great day and finished up "bobbing the nose"
01  head on
02  head on with part cut off
03  slightly elevated
Thanks Sum
Now Francis will modify the Canopy with a 45 deg. slope wind screen instead of the 10 we have now and we should be able to see much better!
Francis came up Friday and we marked the front of the canopy and we cut the top piece off and we will be raising it up enough to have a 61/2 inch vertical windscreen that will be sloped back at a 45deg. angle.  Sumner should be over next week we will begin working on 'cleaning up the nose area and then Francis and I will start on the axle fairing,
We have to get busy if we are going too install a new front axel. build new axel fairings and redo the canopy!!
Quote from: SPARKY on December 07, 2015, 03:56:43 PM
Yep, I agree, maybe I can help with a little of that in a few weeks.  I think put the body work (bondo) on hold until you get the axle fairing mounting figured out,
tauruck
Sparky, I'm blue in the face from holding my breath. :-D
No Pics?????.
There must be something!!!!.
Since the Bonneville problem the forum ain't the same so we live on progress pics
and I'm starved here. :evil:
Guys the canopy is off, Francis came up we whacked the upper part off worked out(we think) the best compromise between aero, ease of construction,  and visibility. Francis now has is down in Tucson.  Hopefully he will post some as he gets going.
My job is to get the axles going I am taking the camber out of the Speedway frt axel and building me a 2.73 12 bolt rear axle for the dirt, so that I can also use the PG/GV set up  for El M.  This will change my FDR from 3.76 in low to 4.80.  We will most likely have to learn how to drive in low but we should come off the truck much better.
One of my next projects will be to get busy airfoiltools.com for some templates for the axle fairings so that I can get done what Sumner is talking about.
lsrjunkie
Maybe a dumb question Sparky, but why are ya taking the camber out?
It presently runs on the outside edge of the Goodyear 21" LSR tires and I suspect that contributes some to its "hunting"  I want to try with the tires flat to slight neg.  not the nearly 5 deg positive it has now.
lsrjunkie
Makes a lot more sense now.
Are you just going to whittle the king pin bosses off the ends of the axle and re-position them, or do you have some cool trick up your sleeve?
And for the record, the cockpit area looks bitchin! I like how you guys flattened that area out for a different canopy.
We are exploring several options:
Modifying the existing axle:
Stainless know the guy that makes these things  may just have him make one with leaving the camber out
or making one ourselves without of solid bar for cg reasons
we dug out one of our 7.5 gem housings---yes it is a gem-- when Marty pushed the tubes out he discovered the axle tube bores are not parallel it has a bunch of neg. camber built in.
I called my buddy Ratcliff and he said that the things were built that way for nearly 20 years some of them were off over 10 degs.
We are going to shorten one good bit and build a rear axle for El M with 2.73 gears so that I will have a 2.13 FDR instead of a 1.66
You called "Propster"?   :-D :-D :-D :-D :evil:
4-barrel Mike
He's active on the Mike Cook's Land Speed Shootout Facebook page: http://hotrodenginetech.com/smokin-the-speed-demon/  :dhorse:
