ROTFLMAO!!!!!!!!   tears streaming
I bet there has be some dope that has tried this out!!!!!!!!!!!!  :cheers:  :cheers: :cheers:
Sparky... Sparky... Sparky... you know how far afield these things can go when you involve the Aussies  :roll:
SS1  ---I believe that Podunk & I have just been enrolled in elementary International Cultural School of Subject Jump--from race parts ---to sex parts ----to Electro Shock "COME on Bully Boy" --------where is that supper sized, motorized  Pogo stick when one needs it
Sparky!???
Sparky said:   "... -to sex parts ----to Electro Shock "COME on Bully Boy"
Just for you, all at one site:      http://www.therimbastore.com/ElectroSex.html
Jon, you pull that from your favorites list or what  :-o
Kinky  :cheers:
You mean to tell me that you don't have a Gold account there, complete with personal shopper?
Uhhhh.... no.... but the winters in Kansas never trap me in the house with Linda for extended periods of time...
If they did, she would move us farther south  :-o
Geezz how things change with time-
-most of my life I might have been considered  as they say on Blue Bloods  "the Perp"
but now I sorta feel like a victim --- my how things change closer to one's 75th
Well things are about to start stacking up---motor to soon be ready---trans should be in hand by June 1st lots going on---must be close to race season :-D
Dr Goggles
Back to our usual programming, that's a relief. :roll:
I'm sorry I even brought that up.
just to help clear the mind here's two old buggers playing some killer stuff,
https://www.youtube.com/watch?v=vbYZXYl50tc
Great video- thanks, Goggles. Here is one back at ya. https://www.youtube.com/watch?v=2wQYdmqK6Tk
#2396
Ordered the 33 spline axles from Moser the longest I could get them is 33.25 which means the shorter one is 32.25 if we are going to center up the pinion.  Marty and I are planning on cutting the stock 8.8 tubes close the housing and then turning down some heavy wall 3" ---we will build the axle tubes to the correct length so that we can have as wide a track as possible. By inserting the existing tube coming from the center section; we hope to increase the strength because we will have a fairly long  tube outside the mounting brackets.
Talked to Francis today and he has been busy making the chips fly on our Rube Goldberg air over hyd. clutch mech.
We have decide to have two air cylinders ---one will be for completely disengaging the clutch. Other one will be used for trans. up shifts only.
I know, I know need to get a camera to Francis.
tauruck
Never underestimate the the old buggers hey!!!. :cheers:
This off season has gone an entirely different way than I thought--we are working on Mechanical things and not aero things..
We soon will start reworking some things in the cockpit for shifter and chute control also will be doing research on rpm signals such as shift lights and such.
