PJ that is what I do most of the time---but Rex I have a water spray bottle to help also.  But I used the wet rag to straighten a bent axle shaft.
it looks like these tubes a pushed in under pressure you can pick up the distortion with the naked eye.
How much air cleaner to filter 500 HP worth of air
Podunk
Sparky,
Maybe the bores in the rear center section are not accurately square to the center line of the pinion and inline with each other. Since you are replacing axle tubes remachining  bores inline with each other and square to pinion in the right location is not a big deal. Then turn new axle tubes to suit new bores.
Terry
WOODY@DDLLC
Francis came up today and we had a long day in the shop getting started on the Target "5%"  hood scoop--lots of noodle time, measuring, cutting fitting and cutting some more.  Ms. Liberty is going to looks so different than before!!
What the heck is going on with suppliers---you call and give them an order they take your money, and then give bogus info about when your order was shipped----or they try to and then you find out that over half of the order was going to be back ordered---then no call as to when it could be shipped.---This is crazy---are we soon going to be trying to race with no SALT and no Hot Rods!!
kiwi belly tank
I have an old pedal bike Sparky, see you on the Utah Dirt Flats & I'll race you for beer's. :-P
PoDunk  does good work
#2441
this is what I was trying to post
We now will have axles that are parallel to each other Thanks to Mr. Podunk
Looking forward to getting the center section back and building the axle
tauruck
He does and I bet there's some good luck built in as well.
Looks good Sparky. :cheers:
ggl205
Francis is working on the hood scoop and I worked on the new exhaust system
