"E" Gas Coupe Build
Started by maguromic, June 01, 2011, 03:15:27 PM
Tman
Pictures will be coming in a couple weeks. I will try and post them up.
maguromic
Trent, If you are talking about the Hondata car, I have seen it and its a very nice set up.  We wont able to do anything like that as the supports will be built into the seat (kind of like a DTM car).  But I am still trying to figure out how far it has to come pass the helmet.  The numbers I am getting are all over the board and even heard of one car at Speed Week that the inspectors wanted 2" pass the helmet, but later was overridden by somebody with common sense. I would like to get a definitive answer though.  Tony
Bob Drury
  Tony, it's in the current rule book:  at least to the front of the helmet.............   I wouldn't build them until I fit the driver in the seat.
  A typical helmet is fourteen inch's deep and ten inches wide, so the padding on the sides (1" SFI) can only be twelve inches inside to inside, and the side supports need to be a minimum of fourteen inches from the front side of the seat back..............  Bob
Bob Drury
Tman
#33
Quote from: maguromic on August 31, 2011, 07:35:56 PM
Tony, no it is the car I mentioned a few posts back. I will post it in the thread talking about restraiants as well, great idea.
I have seen/heard a variety of numbers between a few of the cars I got to be around this year. And they varied from what Bob just posted above + AND -
maguromic
Thanks Bob,  I just couldn't find it in the book.  After reading the rules over a 100 times it all starts to look the same.  Now its clear!  :cheers:
Trent, Post a picture when you get a chance.  Tony
Tman
And since you guys know I am new to this game, all I am doing is reporting my first hand observations as I saw things on the salt this year. A fresh perspective if you will.  I tend to be pretty objective AND think I have a small amount of common sense  :-D  Although the subjects in Tonys avatars could ruin all of the latter!
Cajun Kid
The rule as written says the lateral supports must come forward to the furtherest point of the helmet.. so with the helmet up against the head rest,,, the side supports must come as far forward as the front most part of the helmet,,, which would be the chin bar of the helmet,,
so if the helmet is 14 inches long, the the side bars would be ok at 14.01 inch long.  it does not say they side supports must be xxx longer.
Just my read on it !!!!
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Tman
Just reread it as well Charles, that is how I see it in the book. Ok, it is late here and later there and we are reading the rulebook for fun!?!?!?!??!?! I am so screwed, :-D you can thank my dad the hot rodder and racer :cheers:
38flattie
Quote from: Bob Drury on August 31, 2011, 08:11:12 PM
Bob, we only get 1" of clearance on each side of the helmet? I thought it was 2" per side?
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Tman
Quote from: 38flattie on August 31, 2011, 10:12:18 PM
Yes, 4" max=2" per side max.
maguromic
Today we almost finished cleaning the interior of the sealer, this has to be the worst thing I have ever done (its like watching an ant walk up a drape)! But on a brighter note I started working on the variable steering system. This is something I always wanted to try and with the multipurpose use of this car it will fit perfectly on this project. Tony
maguromic
Finally I was able to get all the part numbers together for everyone that wanted the parts to build the electric dry sump for the rear/ trans.
1 Two stage pump (mine is a Johnson HTP unit with a .800 gear)
1 12 volt electric motor (mine is a Vickers made in Italy part # 9919 123 90023)
1 needle valve -McMaster-Carr # 4995K15
1 72 tooth pulley (style B) - Grainger # 2L534
1 22 tooth pulley (style A) - Grainger # 2L523
1 Gilmer style belt - Grainger # DHJ5  (better carry a few extra)
1 Custom bracket for floor mounting
Aside from the above parts, you will need the nozzles, lines, oil tank with the proper baffles and the breather for the tank.
Hope this helps.  Tony
38flattie
jimmy six
Here's another option on a 12 electric motor. Primitive but it works. Back in the day before electric water pumps, a very resourceful and fast Studebaker owner used a Chevy 6 water pump with it's 2 outlets drive by a Ford 12 volt starter. You remember the ones with the long shafts with the spring on the end? He used a vee belt about 1/3 overdrive which was near stock for the Chevy 6 and only a size #8 or 10 wire and remote solenoid. Never was a problem, never thru a belt, and supplied all the cooling water needed for the Blown Chrysler.......Just  a thought.................Good Luck.
PS: my Tex trans came set up for a dry sump. Pump is between the main case and the rear case............... Looks great Tony
maguromic
JD, That's a great idea to use an old Ford starter motor. The biggest problem I had was to find a proper motor to turn the pump.  Tony
