"E" Gas Coupe Build
Started by maguromic, June 01, 2011, 03:15:27 PM
You've done it again Tony! Now everyone's going to fall totally off topic. :evil: :-D :-D
Tman
I liked the previous one better PJ :evil:
maguromic
Pete, Sorry about that.  But I think they are sisters.  :evil: :-D :evil: Tony
Tman
Quote from: maguromic on October 19, 2011, 08:34:26 PM
We could tell if you made em bigger than postage stamps!
Tman
I have those head restraint shots finally. You want them emailed or just posted here?
maguromic
Trent, Post them so every one can see.  Tony
Tman
Gerry who drives this car had me sit in it and try out their system. You can see a lever to the right of the seat by the fan. The side rest. is hed in place with a spring loaded pin. Pull the lever, tip your head into it and roll out. Works slick. You can see the add-ons required to make it big enough to pass tech. The inside has the SFI sheet padding.
Buickguy3
  Trent,
  I like it! Simple system.
                   [America]
Tman
Quote from: Buickguy3 on November 15, 2011, 06:16:02 PM
  Trent,
Dont give me credit! Talking to Tony tonight he admits he is even in the same club as that car and should have looked all along! :-o
maguromic
Quote from: Tman on November 15, 2011, 08:02:11 PM
  Trent,
That's a great idea and something I will incorporate into the coupe.  I didn't realize he was a Rod Rider till I noticed the sticker on the window.   Trent, thanks for bringing this idea to my attention.   :cheers: Tony
Tman
#55
Small world Tony, thanks for all your input on the phone! Have a laugh with Gerry at the next meeting! :cheers:
maguromic
Not much to add, other than we received the power steering pump (20.1 ratio) back after the changes we requested from CJR.  They also ran it on their steering dyno and gave us some valuable information on the changes we made. This will be hooked up to an electric power steering pump  and will be controlled by a wheel speed sensor and some programed logic that is adjustable from the drivers compartment.  At low speed it will have power steering and at speed it will be similar to manual steering.  The hard part was trying to get the correct torsion bar set up for the box first time around.  Tony
dw230
You have done too much road racing Tony. That is a lot of stuff for a 200 MPH LSR car.
maguromic
DW, I agree its a little overkill,  but I always wanted to try and incorporate electric assisted power steering on to a race car.  The logic is done and now I need to build a small box for the board. The four small buttons on the board control the settings  Tony
Tman
#59
Crazy! In a good way. But I assure you somebody will blame you Tony for escalating LSR into the realm of F1 :roll: :-D
