"E" Gas Coupe Build
Started by maguromic, June 01, 2011, 03:15:27 PM
gkabbt
Quote from: Captthundarr on June 04, 2013, 05:25:56 AM
Yea, "The King of Avatars" is back....
Frank, fixed it for ya! :-D  :cheers:
ROTFLMAO!
Gregg
Captthundarr
Thanks Gregg, it was hard to type after my eyeballs exploded. :-o
gkabbt
Quote from: Captthundarr on June 10, 2013, 05:11:54 AM
I'm with Ya on that one!   :-D
Gregg
maguromic
#378
You guys kill me. Tony
From Seinfeld, Kramer's license plate (taken from the web).
DND
Hi Tony
Thanks for the kind words , just putting in my 2 cents worth and glad it helped
Bob Drury
... it was the Fucilli............. :roll: :evil: :roll:
Bob Drury
maguromic
Not a very fancy model, but this is the layout of the rear suspension. Its in board and out of the airstream, and can be easily adjusted from the back of the car. Steve had to draw some brackets up to modify the Panoz rockers we were going to use.  Also we  had to switch the dampers (the ratio didn't work out for what we wanted) we were planing on using to get the correct droop travel and bump travel we needed.  Tony
DND
Hi Tony
That's about as Sano as it gets dude, couple of brackets and a few bolts and you are off and running
maguromic
I have been swamped at work and haven't had a chance to work on the car, but my neighbor brought the antenna cover for the roof top he made. It still needs to be trimmed and fitted with the cam locks, though it snot much one more thing crossed of the list. The mold for the part was posted some time ago on post 213.  Tony
dw230
Antenna cover? Roof top? Contour change?
maguromic
Quote from: dw230 on July 04, 2013, 09:17:51 AM
Instigator, Happy 4th Dan.  :cheers:  I guess all those cars with roof flaps would be in the same boat.  :evil: Tony
krusty
      As long as your antenna cover leaves a minimum of 35% of the original roof visible when viewed from above...
      vic
Dynoroom
Quote from: krusty on July 04, 2013, 12:44:22 PM
      vic
Now that there is funny......    :cheers:
'specially coming from a REMR guy.
krusty
     Thanks, Mike!   :evil: :-D
dw230
Tony,
Roof flaps do not change the contour, they are flush with the top.
Vic,
Where did you get the 35% from?
