fordboy628
Quote from: Milwaukee Midget on March 25, 2013, 01:16:55 PM
I understand a videographer will be making his way up from the cheeseless plains of the snow covered southern hinterlands, so Wisdonm and Fordboy, clean, non-offensive T-shirts, please . . .
Boy, add nearly a year of age and all the fun just evaporates faster than Jamesons on a hot summer day. . . . . . . . . . . .
Since you've gone to the trouble of sending E-invitations, I'll attend in "Black Tie".
F/B
wisdonm
Damn you guys. Now I have to get a new t-shirt.
Has a checkered past.
4-barrel Mike
Chris, have a couple similar to those that I wore under my flight suit...  If you need them for emergency overshirts for the boys, send me a PM and I'll mail them to you.  :-D
I can just see the article in "GQ"  . . .
"Fast Forward Fashion for a Fine Dyno Experience".
Hell, I should talk - I'll consider myself lucky if I've got clean sox on the 3rd.
Well, this was a productive day.
I was able to confirm my last measurements at the dyno shop, and they have extra long ignition wires I can use, so I can set my ignition box close, but not too close.  This will be sans my digital analog conversion effort, which I've moved to the back burner - I have enough on my plate, and the ignition I have works fine.
I dropped off a pilot bushing to be turned down at C&S, and Mel didn't run into the back room and hide from me.  He'll become more scarce when I pull the engine from the MGB, I'm certain.
All but one of the coolant lines are in place - I need to stop and pick up a section of 9/16 heater hose and some clamps, and that will put that to rights.
Breather vents plumbed.
Fordboy, a question for you.  How much fuel do you think we'll need?  A 1/2 hour of run-in time and let's say a dozen pulls?
fordboy628
#2315
Quote from: Milwaukee Midget on March 25, 2013, 08:35:44 PM
"Fast Forward Fashion for a Fine Dyno Experience".            Ah, alliteration.   Your Achilles heel, so to speak. . . . . .
Hell, I should talk - I'll consider myself lucky if I've got clean sox on the 3rd.      I will have clean socks by design. . . . .
Well, this was a productive day.       Updates to dyno checklist recorded. . . . .
I was able to confirm my last measurements at the dyno shop, and they have extra long ignition wires I can use, so I can set my ignition box close, but not too close.  This will be sans my digital analog conversion effort, which I've moved to the back burner - I have enough on my plate, and the ignition I have works fine.    Thankfully. . . .
I dropped off a pilot bushing to be turned down at C&S, and Mel didn't run into the back room and hide from me.  He'll become more scarce when I pull the engine from the MGB, I'm certain.       Updates to dyno checklist recorded. . . . .
All but one of the coolant lines are in place - I need to stop and pick up a section of 9/16 heater hose and some clamps, and that will put that to rights.       Updates to dyno checklist recorded. . . . .
Breather vents plumbed.      Updates to dyno checklist recorded. . . . .
Fordboy, a question for you.  How much fuel do you think we'll need?  A 1/2 hour of run-in time and let's say a dozen pulls?       See below. . . . .
Midget,
Let's presume:
1/    A resultant of .55/.60 BSFC       (this is about where you are going to end up, based on my previous experience.)
2/    A max of 15/16 pulls,  @ a max of 60 seconds elapsed time per pull   (probably will not take that long at 300 rpm/sec [10 seconds] or 100 rpm/sec [30 seconds]
      acceleration rate. . . .    based on an rpm spread of 5500 rpm to 8500 rpm for a net of 3000 rpm/acceleration rate.   Steady state step test may take slightly longer.)
3/    .5 hour of run time for break-in at say 1/2 throttle, so lets say approximately equals 1/4 hour @ full throttle    (over estimated. . . . .)
4/    Your fuel specific gravity of ??      (.700 to .740 would be the normal range for 110+ octane gasoline, but let's say 5.8lbs/gallon [.695 sg] to over estimate. . . . . )
      [.74 sg * 8.345 lbs = 6.175 lbs]    {VP Blue = .733 sg;  ERC A-19A = .699 sg}         http://www.smithtex.com/racing/fuelcomp.html
OK .    So a total of 1/2 hour full throttle run time * .60 BSFC * say a max of 100 bhp = 30 lbs of fuel consumed divided by 5.8 lbs/gal = 5.1724 gallons    [4.86 gal @ 6.175]
5 gallons minimum, because you don't want to run out in the middle of a pull. . . . . .     You might want to run in on race fuel they can supply, (only if it meets your engine's requirements. . . . ) to preserve your stuff for the full throttle pulls.   Or bring more than 5 gallons.
Will post an updated Dyno Checklist later this week when I have the carb linkage finished.    I think I can get a tux made in woodland camo in time for this schedule. . . . . :-D
edit added website,  F/B
wisdonm
That's a whole tank of gas!
fordboy628
#2317
Quote from: wisdonm on March 26, 2013, 01:17:51 AM
Is there anywhere in Beerhaven where you can get Premium Leaded?    Or Aircraft Premium Leaded?     I'd be nervous about anything less than say 100/102 octane (R+M/2). You could carefully run-in at part throttle on those, before you shpank it.    But the little voice in the back of my head says it is probably not worth saving $5, or even $10, versus the value of the engine. . . . . . . . .
How well do you know the Easter Bunny?    You really don't want to lay an egg at this point. . . . . . . . . . .      False economy has a giant set of teeth. . . . . . . . .
Quote from: fordboy628 on March 26, 2013, 05:55:23 AM
. . . . . . . . . . . . and that's the whole truth!
fordboy628
Quote from: Peter Jack on March 26, 2013, 06:03:54 AM
Yeah!     Don't ask me how I know. . . . . .
F/B
fordboy628
Midget,
I know you are concentrating on the engine.   But check out some of the brake drag reduction ideas on the tech thread for later on . . . . . . .
F/B
Okay, that tells me what I need to know.
I've got some 114 left over from last year that's been well sealed - I'll go pick up another pail.
I have 2 gallons of VP C-14   SG .696    114 Motor Method
There would have been more left over, but the snow caught me with an empty tank of regular.  That was fun, following around a Toro dual stage with the ultra rarified oder of burnt racing fuel causing a mild headache.
At Bonneville, I think I'm looking at
ERC - A-19A  SG .699  117 Motor Method
I'll confirm that and try to find a VP product close.  We can do the run in on the old stuff.
fordboy628
Good Plan.
See, you're getting smarter already, even without the trick calculator. . . . . . .     :-D
F/B
Dean Los Angeles
Quote from: Dean Los Angeles on March 26, 2013, 07:27:04 AM
Required wear, no?
Dean, how long did you work in wardrobe at Warner Brothers?
I think our L.A. fashion consultant has picked a winner!
A link?
Another one I'm looking at -
http://www.cafepress.com/mf/19344423/aseries-engine_tshirt?shop=Acmespeed
