fordboy628
Quote from: fordboy628 on April 16, 2013, 07:07:04 AM
Working on adaptor for cable throttle.   Will post pics later today.
Mickey Mouse   (RIP Annette. . . . .)
While the cat's away the mice will, . . . .  are busy working on more dyno adaptors!     Part Deux. . . . .
(well, technically the cat is back, but that doesn't work on this little thread diversion. . . . . . . . . )
Midget,
As promised, pictured below:
For long playing axeman, extended (album) version of throttle adaptor, for cable actuator. . . . . . . .
Manfred Maus
(Der Deutsche cousin von Mickey)
fordboy628
ALSO:
T- 12:00 and counting down. . . . . . . . . . . . . . . . . . . . .
Rocket man
Mice like you sure are handy. Keep up the good work Fordboy!!!  :cheers: :cheers: :cheers:
Quote from: fordboy628 on April 16, 2013, 06:04:53 PM
Gosh, I was expecting variegated padauk, teak and maple, but I suppose metal will do . . .
It IS easier to weld . . .
So - will it be back from the chrome shop by 8?  :wink:
Okay - sincerely, THANK YOU.
I called and verified our appointment for Wednesday - there is no other engine on the dyno, so we should be able to plug and play.
The car is loaded, the alarm and coffee maker are set, Wisdonm is going to be by early, and all I have to do is stop at a truck stop and pick up fuses for the ignition.
Reports to follow - and by the way, Cecil Kimber's 125th birthday celebration in Bennington was ubercool.  More on that when I get some time.
fordboy628
#2449
Quote from: Milwaukee Midget on April 16, 2013, 09:31:13 PM
VE DON'T GOT TO SCHOW YOU NO STINKIN' BEANIE AND CECIL!!!!!!!!!!!!!
Dimunitive Denizen von "Beerhaven",
Vhat ve vant ist a photographic essay uf da "Schpanking".    Ve vould prefer photos/videos dat feature "Mistress Helga", und not some oldt, fat, wannabe, "Saltine" racers. . . . . . .
Manfred Maus (resident von der Reeperbahn am Hamburg, St. Pauli Distrikt)
P.S.   T- 2:33 und counting. . . . . . .
fordboy628
Mein vood velding hast been suffering lately und metal vill hab to do. . . . . .
:cheers: und schtill counting down,
Werner von Braun Maus (cousin to Manfred. . . . .)
Graham in Aus
Good luck today guys!
101 @ 7800 !  :-P
Nice cake!  :-D
SteveM
The excitement is nearly overwhelming!!!
Duck-Stew
Team UnorthoDUX
4-barrel Mike
Dr Goggles
they have had a visitation from the Prince of Darkness, he has walked throught the valley of ignition and sparks aren't flying,that's all I know.
I heard it on the txt vine
Hopefully Chris took some smoke with him.... I thought he eliminated the Lucas parts  :roll:
I guess no news is not good news
It'll all be fine – it just won't be fine today . . .
First, a disclaimer:
NO LUCAS PARTS WERE INVOLVED IN THIS ABORTED ATTEMPT.  NO MIDGETS WERE HARMED DURING TODAY'S EVENTS, AND NO SMOKE WAS RELEASED FROM THE WIRES.
In preparation for today, the entire electrical system needed to be removed from the car.  There is no distributor – it's an Electromotive crank trigger system.
Contrary to previous posts by myself, no modifications to the system were involved, and to my great shame, I must add that the idea of a peizo-digital/analog converter was really rather stupid, and a path that I neither attempted, nor will pursue.  In fact, the ECU and ignition packs were simply removed from the car, and a new harness was purchased and installed on a test box for the sole purpose of this session.
The problems that occurred were as follows –
The data cable from the computer to the ECU got warm.  I don't think that's supposed to happen, but it did not bode well for the rest of the attempt.  A careful testing of the ECU data port indicated 4 of the computer port pin-outs were showing 12 volts DC.  Again, I don't KNOW, but I don't THINK that's supposed to be the case.
A call to electromotive indicated that they did not know why a data cable would get warm, but they did help me address an oversight on my part.  While I did have power going to the coil packs, I did NOT have power going to the ECU.  I had brought my soldering iron for just such an oversight, and repaired the problem.
Further investigation discovered that I had set up the multi pin plug to the coil packs for the wrong half of an 8 cylinder engine.  There are pins for two sets of coil packs for a V-8 installation, and I had set up the pins on the cabling to the ECU on the side of the nonexistent signals that the chip in the ECU may or may not have etched into its RAM.  The cabling was remedied with Don's faithful and patient assistance.
Either through my error or through a faulty ECU, the unit would not fire up and blew fuses.
So tonight, I'll tear into my half of the voodoo box, and prepare the Electromotive unit for shipping and testing.
Mark and Don were absolute champs.  While I stumbled with the electrical, along with Tom, the owner in assistance, they had the engine rolled up, bolted up, linkaged and plumbed by about 9:15.  That part of the plan went off without a hitch, due in large part to Mark's design work, Don's intuitive mechanical ability, and "Wigglepin's" excellent machine work.  Having done a dry run today, I expect it will go a little quicker next time.
So, that's that.
Photos courtesy of Wisdonm –
Captthundarr
DAG and double dag, well at least there were lessons learnt and no mechanical parts busted, endeavor to persevere....
Frank
fordboy628
#2459
Quote from: Milwaukee Midget on April 17, 2013, 04:41:08 PM
So, that's that.
Protons, neutrons, electrons, quarks, leptons, bosons, photons, hadrons, baryons, mesons, pions, kaons, gravitons AND, probably a couple other particles I inadvertently left out.
I hate 'em all, necessary little bastids. . . . . . , some probably don't really exist, although I'll grant you that electrons DEFINITELY exist!!!   (Don't ask me how I know this. .)
Give me some aluminum stock, AutoCad, some machinery and some files, you know something. . . . . , TANGIBLE. . . .
Something I can see & use.   Like to hit the head of the underperforming left tackle of my football team, oh wait, can't do that anymore either. . . . . .
Guess I'll just grab another Leinie's. . . . . . . . . . , and do the MG dance. . . .    3 steps forward, 1 step backward, 3 steps forward, 1 step backward. . . . .
Hey!!   I think I can see white, verwy, verwy, verwy far away. . . . . . . . . .
Elmer (Electron) Fudd
65 psi oil pressure on the starter is a good thing, right?  RIGHT?  RIGHT?       (This happy face PMA crap is killin' me. . . . . , It's the suds keeping my head afloat. . . . . . . )
