38flattie
Quote from: Milwaukee Midget on July 06, 2013, 12:01:04 PM
A little down time - so I ran off to, "gee, I wonder if . . . " land.
I dug around the slag pile that is my used BMC engine parts corner of basement world and pulled out an old 948 block.  Dale posted up the diameter of the Harley Davidson tappets the Flatcad is using - .750, which is smaller in diameter than the .812's in the Midget, but are of a roller variety.  The 948 has an open tappet chest - the 1275 block is solid, but they're similar enough that I'm thinking I might be able to pull this off for next year.
Just bouncing some numbers around, but I'm thinking a machined insert might accommodate a modified Harley roller tappet in the Grenade.  :roll:
Chris, these custom one off lifters would probably be cost prohibitive to buy.
....but, I have tons of Harley rollers lifters, that would probably work, with a sleeve, and maybe a few mods. I'll throw a handful in the pickup, and give them to you on the salt.
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
I'll pick 'em up in 30 days!
All part of the grand experiment . . .
fordboy628
Midget,
You might need a block with a tappet chest for this.  Let me know if you want to check out the 2 early 1275S blocks I have in my garage.
From a practical standpoint, I think you would be better off to fit larger OD tappets from BWR by reaming the block to .842"/.875" diameter.
Oh, BTW, RACE THE DAM* GIT BEFORE THINKIN' ABOUT CHANGIN' IT!   :roll:
P.S.  Consumed the Hive Initiative Chocolate Mead last night, very tasty . . . . .   trying to get out of my Lienie's Dark Lager rut . . . . . . .
:cheers: :cheers: :cheers:
F/B
Quote from: fordboy628 on July 12, 2013, 06:41:40 AM
Well, actually, I was thinking that if Buddy's going to bring tappets, we could just pull the engine in Wendover, run the block to SLC, have 'em whip up the inserts and clearance the block from the drawing we'll do with crayons on the back of a cocktail napkin, haul it back, bolt it all together in 100 degree heat, and see if it works.
:roll:
Well, maybe not . . .
Vintage racer's creed -
If a job's worth doing, it's worth putting off to the last minute . . .
Dean Los Angeles
Don't forget the DBC credo . . .
Duck tape
Bailing wire
Chewing gum
Quote:  thanks for your input, and thanks for checking out my slow spiral into madness!
Are you defecating me?
You are in a super sonic plunge passing thru madness on your way to oblivion.
That's why there is so much interest in your final outcome.
We want to know how to avoid your destiny.
It's also fun to laugh at those who are in deeper doo-doo than we are,
but you do seem happy and green.
Quote from: Freud on July 12, 2013, 01:06:42 PM
I was following you . . .  :|
Why do MGs rust?  Well, a lot of it has to do with the fact that there are so many open areas where crap collects.
One of the key areas is in the lower rear of the front fender.  Dirt, road salt and moisture gets kicked up between the inner fender and the outer fender, and short of removing the fender and cleaning it out, there's really not a lot you can do to stop it.
Driving it on a surface of salt is a recipe for disaster.
This won't cure it, but it should help.
It's garage door weather strip, riveted to the lip in the inner fender.  It permitted me to trim the inner fender wells for additional clearance in a tight configuration without having to radius the wheel wells.
So the Midget retains its charming good looks and still maintains its "do-it-yourself" punk attitude.
A couple of pieces of rubber sheet were also employed to keep salt from kicking up into the engine compartment and getting into the carb and onto the electrical.
I'm a few washers short of finishing (I've always been a few washers short) but it's one of those niggling little things that has bugged me just enough to do something about it.
The new bar in place – padding is on order – should be here by the end of the week along with a new oil filter and some 5W-30 Brad Penn.
Dr Goggles
Quote from: Milwaukee Midget on July 15, 2013, 09:01:08 PM
They aren't on their own there. Jags are worse,but it's a characteristic of Pommy cars from the dark ages I don't quite understand why they didn't copy one of the many better ways of buttoning up the front clip, they used so many bolts, so much metal and yet somehow got so busy with that part of it that they didn't think to drain it and avoid dust traps , god bless 'em.
What you've done there looks great, pull it apart and hose the bugger out, you'll be right.
More importantly remain calm and remember to have fun, short of an act of god this thing is gonna fly and when you come home with a record you also want to have had a good time, concentrate on that bit as well, don't over prepare ALL of the fun out..... you're lookin good. :cheers:
This has been a long strange trip brother, keep on truckin  :mrgreen:
Elmo Rodge
Like the good Dr. said.  :wink: By the way, I like the way the new bar looks. That was a gaping hole there and you plugged it without limiting egress except through that hole at an inconvenient moment.  :roll: See you in a few weeks.  :cheers: Wayno
wheelrdealer
MM:
Getting closer. The car is never DONE so it will always be a few washers short.
Looking good. Building the Midget was one thing but you took the time to post and develop 188 pages for build diary thread for all of us to share. There are a bunch of us that now know this car well. We will all be on board in spirit. Everyone dreams but only 1% build the dream and execute the dream. Welcome to the 1% club. Yes there is a hat...not sure what color it is but it will say Bonneville 2013 Participant. Yes it is worth every effort and $.
As far as the salt, it is going to get everywhere. Use a lot of anti-seize, WD 40, clear coat and plan on striping it down when you return.
Quote from: wheelrdealer on July 16, 2013, 06:27:18 AM
MM:
Thanks, Bill.
I'm glad it will be in spirit, because to tell the truth, there's not a lot of room for passengers.   :cheers:
I've had a number of projects in my life that have never come to full fruition.  I can't let it happen to this one.
There was a column by Peter Egan that I have clipped at home.  He and a buddy of his were taking some practice laps, and another fellow comes up and says, "I've always wanted to do that".
His buddy says, "No you haven't."
Essentially, the column goes on to explain that if you've always wanted to do it, you'd be doing it.
And I don't want to be the guy that Peter's buddy had called out.
By sharing this build, I am always "putting it out there", and because it's documented for the whole world to see - warts and all (and when it comes to beverages, worts and all) - it keeps me to task.
You can call me on some of my BS in the build, but I won't be called out for not making it happen.
It's become important to me personally.  I don't need a hat, I don't need a record, I just need to give it what I know is my best shot.
And if this shot doesn't do it, I'll reload.
The encouragement I've received from this site has been key to getting it this far.
And I can't thank Fordboy enough.  He brought a degree of discipline to the engine development I would have floundered with.
So now I guess I've just got to go drive the damned thing.
Captthundarr
that is using your noodle Chris, drive on Macduff.
wheelrdealer
Chris,
Exactly, it will be worth the effort.
I said it for 40 years and one day I decided to make it happen. Business and cubic dollars will limit me to every few years but all spare time and dollars are devoted to getting back to Speedweek.
fordboy628
Quote from: Milwaukee Midget on July 16, 2013, 07:28:04 AM
Midget,
Gosh, golly, gee, Thanks for the kind words.   But I didn't do much.   Crunched some numbers, pointed out the obvious, did some analysis, recommended some testing, etc . . . .
I leave the discipline to Mistress Helga . . . .  she's better at it . . . . . .
I'm just doing this to fill in until I can get hired for my dream job . . . .    barley based beverage taste tester . . . . . . .
