jpm49c
On his second run a couple hours age he ran 102.464. Way to go!
wisdonm
#2911
Chris just ran 118+. Not enough yet. And the course is closed for the day.
Has a checkered past.
fordboy628
Guys,
My info, direct from the speed maven from Beerhaven @ 6:30pm, Central time:
Tech line: Car passed through OK.
Rookie run: Approx. 100 mph, no problems.
First pass, short course:  116.698 mph @ 7300 rpm.  Driver reports easy shifting @ 7900/8000 rpm for 1/2; 2/3; 3/4 shifts.
       Driver also reports: NO PROBLEMS with close ratio gearset/gearbox.   NO PUSH OFF REQUIRED . . .
Target rpm of 7800 in 4th gear = 124.691 mph!
Driver is in line for a second pass, may happen today if course is cleared, or first thing tomorrow morning.
Driver has suggested:  More aggressive rpm use & shift points; 8500 rpm 1st to 2nd; 8500 rpm 2nd to 3rd; 8400/8300 rpm 3rd to 4th.
Mistress Helga agrees und says: "Time fur ze schpanking!!  GO FOR IT!!"
:cheers: :cheers: :cheers: on a personal best ever run . . . . . .
P.S.   530.445% IMPROVEMENT IN TOP SPEED OVER LAST TIME . . . . . . . . . .
fordboy628
Midget,
If your coolant temps are too low, consider a hotter thermostat, say 185F or 195F as a last resort.
Rob
#2914
wisdonm
Wouldn't taping off the radiator be better? Not grill, radiator.
Dr Goggles
All hopin for the best for our man from Beerhaven.....I got a txt after the 116 run.....go you good thing!
fordboy628
Quote from: wisdonm on August 12, 2013, 07:50:58 PM
Don,
Yes, taping off the radiator would be better & faster . . . .     But this isn't the SCCA, it's the SCTA, where taping the radiator is illegal in GT classes . . . . . .       (and you thought the SCCA was difficult . . . . . . .)
Makes no sense to me either, BUT, it does make the cars faster, SO, not allowed . . . . . . . .
warspite
fordboy628
Quote from: fordboy628 on August 12, 2013, 07:15:40 PM
Midget,
Midget,
Is there a way to reduce or eliminate airflow though the extra radiator?   Perhaps remove it altogether and link up the hoses?   Just spittin' out ideas here . . . .
BTW, I believe I can now count you as a convert to my religion, you know the one, "Ah, you thought about this first."
On the road for part of the day, use my cell # first.
BTW, Improved capacity kegerator for the "project cave" now installed & chilling world's favorite beverage.   (I have had to compromise and allow "wine".    Sacrilege, I know.   But it just wasn't worth the dogfight.
Let me know if you are going to stop below the "Cheddar Curtain" prior to returning to "Beerhaven".    I believe I can requisition some "Olde Speckled Hen" or another celebratory beverage of your choice.   And the grill still works fine, so just let me know.    I believe you are aware that I like to "plan ahead".
Best of luck for the remainder of your effort.   Remember, NO COMPLETE ROTATIONS ABOUT THE PITCH OR ROLL AXIS ALLOWED!!    A small number of complete rotations about the yaw axis are permitted, followed by mandatory undershorts laundering of course . . . . . . .
wisdonm
Chris just ran a 115.878 this morning.
gkabbt
Don, was this his 1st run of the meet?
Gregg
gkabbt
Nevermind.....Just saw your post earlier in this thread?  :oops:
wisdonm
No. About 9:30am 8/13/13. You would think someone that is six foot five would have heavier feet.
gkabbt
Quote from: wisdonm on August 13, 2013, 08:43:22 AM
ROTFLMAO!  :cheers:
Gregg
