XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
That could be it.  I'm registered on the HAMB, tho I spend very little time there.
Quote from: Peter Jack on October 25, 2013, 12:20:20 PM.... I think you have to be registered in the HAMB board to be able to see the pictures...Pete
You do have to be logged in over there.  Once I went over there and logged in I can see all of the previous pictures posted along with the ones I posted.  I'm registered on the HAMB but haven't been logged in there for some time.
The pictures need to be posted somewhere else other than the HAMB and linked to or you need to upload them off of your computer to here.  Linking to the HAMB just isn't going to work if you want everyone here to see what you are posting,
4-barrel Mike
Years ago, Ryan would get side-ways angry with people who cross posted pics off of the HAMB.  I haven't logged on in years, so I don't know about now.
Tman
Quote from: 4-barrel Mike on October 25, 2013, 02:11:00 PM
Not at all, he has always welcomed it.
Graham in Aus
Can confirm this, first look, no pics, open HAMB in another window, log onto HAMB, come back here and refresh....
Pictures!
Well done Sum!  :cheers:
38flattie
#2135
Well, it appears as if the picture mystery is solved, so we can move on to other things!
The block is at Lock-N-Stitch, to be repaired. When it's repaired, we will hone the bores, and start the assembly process.
The MSD Dizzy is headed back to MSD, for a freshening up. We'll Probably run a MSD 20 mag next year, so this dizzy will be a backup.
The gear drive is repaired, and headed back to us! I reported how the initial call went, but since then, my opinion has completely changed!
Donovan feels we may have a clearance issue on the crank, and that may be putting the idler bearing in a bind. Their second thought is inadequate oiling. In spite of the fact that they feel we may have inadvertently caused the problem, They paid for all of the repairs! I only had to pay for a new front seal I requested, and the shipping!
Donovan has now set the drive up with a crank gear that is cut a few thousands deeper, to help with any clearance issues we may have. I have to give MAJOR PROPS to Donovan, for really standing behind their product!!!! :cheers: :cheers: :cheers:
Don and I looked the drive over when I was at his house last week, and came up with a plan to add oil sprayers to it, so hopefully we can cure any oiling issues we may have.
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
38flattie
I believe some motorcycles had aluminum head gaskets.
Is here a reason that copper is used, instead  of aluminum? Don has the capability to make aluminum head gaskets.
It seems to me that if a soft aluminum were to be used, it would work very well with our o-ring/receiver groove setup.
I'm thinking of a soft, annealed aluminum:
6061-O Soft Annealed Aluminum Alloys - Sheet
   Sheet
larger image      This is the most versatile of the heat treatable aluminum alloys. It has most of the good qualities of aluminum, and it offers a wide range of mechanical properties and corrosion resistance. It can be fabricated by many of the commonly used techniques.
In the annealed condition it has good formability. In the T4 condition fairly severe forming operations may be accomplished. The T6 properties may be obtained by artificial aging.
It is welded by all methods and can be furnace brazed. It is available in the clad form ("Alclad") with a thin surface layer of high purity aluminum to improve both appearance and corrosion resistance.
Specifications: QQ-A-250/11, AMS 4025
Color Marking (Rod and Bar): Ends painted Blue
RichFox
#2137
If he can make aluminum gaskets he can make copper gaskets, I would think. I did a "Make your own copper head gasket" piece for the BRN  few years ago. Not hard to do. Bob Dalton punched out an aluminum gasket for me to try out my dimensions, and then used the same program for the copper ones. So CNC punch press or Bridgport it's pretty easy if i can do it. In fact I found a picture from that story
4-barrel Mike
Tman
No pictures for me this time also.
38flattie
Quote from: RichFox on October 29, 2013, 01:43:11 PM
Don can laser cut aluminum. We would do a masking and chemical etching in areas to reduce the thickness and leave a band around the chambers and the studs. Just some Ideas we are messing with-I can't see wht it wouldn't work.
mike, Trent-there are no pics this time! The only pic was a flat piece of aluminum in the description I copied ans pasted! :-D
Tman
Quote from: 38flattie on October 29, 2013, 02:30:08 PM...mike, Trent-there are no pics this time! The only pic was a flat piece of aluminum in the description I copied ans pasted! :-D
Was the picture from HAMB again?  If so that isn't going to work for a number of people on here  :cry:,
38flattie
Quote from: Sumner on October 29, 2013, 02:58:33 PM
Sum, I think we've learned our lesson about the HAMB pics! This was just a pic of a flat sheet of aluminum that was in with the product description. When I copied the text, the pic simply didn't post with the text-I didn't try and post a pic.
Quote from: 38flattie on October 29, 2013, 05:17:43 PM
Great, I didn't see the 'flat sheet' so started to panic  :oops:,
