XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
fordboy628
Quote from: 38flattie on April 22, 2014, 09:53:09 AM
Quote from: Jack Gifford on April 18, 2014, 09:34:48 PM
What O-ring wire diameter? Block groove width and depth? Receiver groove width and depth?
Wire:  .041
Groove Width in Head:  .0395 (interference fit - very important of it won't stick!)
Groove Depth in Head:  .026
Protrusion:  about .015 proud (wire in the head)
Receiver Groove Width:  .055 to .060 (centered with the head groove)
Receiver Groove Depth:  .012 to .015
All these dimensions seem pretty normal for o-ring set-ups.    I suspect that the .085" (14 gauge? listed as .0863") thick copper conforms/deforms less than a 21 gauge sheet (.0320") or even an 18 gauge sheet (.0485")
pops29
Quote from: Jack Gifford on April 22, 2014, 09:32:29 PM
Thanks. With those odd-shaped rings/grooves, I assume you did the grooves with a CNC program? With locations referenced to head dowels?
Yes I did -- I did both the dowels and the groves on the same setup
Jack Gifford
#2282
It appears to me that the .080" gasket thickness defeated the intended function of the O-ring and receiver groove. Using your dimensions I sketched to scale a cross-section view. It looks as if the movement of the gasket into the receiver groove would be insignificant. The other scale-sketch is of the O-ring scheme in my blown alky hemi V8- where the receiver groove and the .024" gasket form a labyrinth-type seal.
M/T Pontiac hemi guru
fordboy628
Quote from: Jack Gifford on May 05, 2014, 11:06:55 PM
x2
Roseville Carl
"Keep Em Between the Whites"
and yes Virginia the world is indeed Flat
38flattie
Thanks Carl, and good luck at Eagle field!
We're headed to El Mirage, to run on a 185 MPH minimum in XXO/BFCC
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Elmo Rodge
When are you heading out, Buddy? Wayno
38flattie
Wayno, I fly into Sacramento tomorrow-I left the car, trailer, and truck out there. We'll be on the lake by 9 Friday morning.
saltwheels262
good luck to you and all others going to em this weekend.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
tauruck
Have a blast Buddy.
We're always pulling for you from this side.
Be safe. :cheers:
38flattie
Thanks guys! I'll post up results of our escapades next Monday or so!
Roseville Carl
Kool Buddy go gettum........ I will be thinking of you guys while running at Eagle, maybe next time you run down there I can make it!
kustombrad
Saw the beast yesterday and I must say, what a cool car! Hearing the weight of the motor cracked me up (freakin' heavy!) and the difference from Ford to Caddy flathead was pretty cool! While I was standing there talking to (I believe Bored and Stroked) about pushing out head gaskets and other weird issues, I asked what size head studs he was running. I know guys who have run fuel in BBC motors and stepped up from the 1/2" studs for more clamping force, so I can't see how this motor can hold anything from moving around with 7/16" studs! The car is awesome and I love the concept, but if there's room I'd stuff 1/2" studs in there at the very LEAST! Just my opinion guys... see you on the salt!
38flattie
Quote from: kustombrad on May 18, 2014, 10:05:32 AM
I think you are probably right, but it is too late for us to change this year-it is on the winter 'to do' list though.
For Bonneville, we'll have deeper head chambers, so we'll run a .035" thick head gasket, instead of the current .085" gasket-hopefully the O-rings will work better with the thinner gaskets.
38flattie
We've been busy modifying the exhaust
