XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
38flattie
Tonight we added blisters. We still have some work to do, but it's coming along.
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
tauruck
One of my favourite cars!!!
Looks good Buddy. :cheers: :cheers:
Roseville Carl
The never ending quest continues looks great Buddy!! betcha can't wait to get her on the salt!
"Keep Em Between the Whites"
and yes Virginia the world is indeed Flat
lsrjunkie
Right on Buddy! Looks great!  :cheers:
38flattie
Thanks guys !
Picked up a rebuilt Caddy flathead today......
You still won't be able to run Production.
38flattie
Roseville Carl
What's going on in FlatCad land lately???
WZ JUNK
I am working on the front fenders and then I need to make a couple of repairs on the hood side panels.  Randy is busy with some other projects.
Crew chief #974 B/BGCC 1953 Studebaker Past Bonneville record holder.
tauruck
38flattie
In addition to what information John just provided, Don deepened the chambers today, and now will polish them. This will allow us to run .035" gaskets, which I hope allows the o-rings  to work better.
I'm at work, but will install the heads when I get home .
38flattie
Don is deepening the head chambers, so that we can run a thinner head gasket, and hopefully take full benefit if the o-ring/receiver groove setup. He still needs to polish the chambers.
He has the first head done, and deepened it .050", so we can use .035" copper gaskets.
Roseville Carl
WZ JUNK
I have made the first part of the repairs to the front fenders, hood side panels, and hood.  I filled the holes in the front fenders where they were cut out to allow for tire clearance.  The tires touched the fenders, when Buddy applied the brakes, after the 189 mph pass on the salt.   Randy will raise the car up so that now the tires will clear, and the holes are no longer needed.  This will get the car back to the correct angle or stance that I had planned when I set up the rear spoiler and front end.   The hood side panels had been modified a couple of times to allow for different versions of the headers.  I filled in these areas and Randy will make new cutouts for the newest headers that he has made.  I repaired two small areas on each side of the hood that were cut out for header clearance.  I will finish all of this by doing the other half of the job, which is fiber glassing on the opposite side of the repairs.  I make the repairs by beveling and fiber glassing from both sides.
I am also making a plug to go into the engine air intake on the hood, to close off that hole when the car is in transit or in storage.
My stuff will be done soon, and then parts will go to another shop for bodywork and paint.
tauruck
That is some serious machining. :cheers:
