#870
"Two piece" heads? :?
Since (you said) you had to lower the compression ratio, how come you didn't enlarge the heads' valve pockets for flow gain?
When we had the heads machined, we had only the Joe Abbin numbers to go off of. It was only when Garry flowed his head against ours, did we realize the issue.
Garry is doing some more testing for us, as we suspect the transfer area may need reworked. When we know exactly what we need, we'll 'trim' up the chambers.
I received my FIRST ever (hopefully first of many) Speedweek timing tag today!
I know this is old hat for most of you, but I was excited!
The pics didn't turn out very well, but it sure is cool!
Congrats!
Get enough of those and you can lose the ballast.  :cheers:
GH
Buddy, the RED ones are the ones you want.
Quote from: GH on February 19, 2012, 06:33:02 AM
Baby steps, Gary, baby steps!
....and a blown Jimmy 12 port! :-D
I guess you don't want us to read it.
Haha! I took the pic at the house yesterday, now I'm back in PA. It says I was there, but did nothing memorable except show up and run!
I still don't see a "two piece head"? :?
RichFox
In order to machine water jackets in the billet heads there is a bottom piece which is in contact with the gasket surface and contains the combustion chamber, transfer passages and spark plug threads. Everything you see when you look at the bottom of a flathead. It is also machined for the coolent passages. The finned top half seals in the water jackets and looks pretty.
BoredAndStroked
#880
Okay - having trouble with attachments . . . maybe because I'm a newbie with attachments on this site.   So - if you see the same stupid thing 45 times, you'll know the reason.  ME!
Monday Build Update:  Buddy has asked me to post some more pictures . . . here are the latest from this evening.
1) Finished the mounting of the crank snout support system -- uses a big roller bearing on the outside of the snout hub to take strain off of the crankshaft snout and also acts as sort of a '4th Main' for our 3 main FlatCad.   The crank hub goes on really tight - to reduce the chances of any run-out and/or any opportunity to wobble.   Once you put them on, you have to use a stout puller to pull them back off  (which I have).
2) Then I put all the blower manifold, intercooler and drive setup in place - to validate belt lengths and pulley options.   We can swap the lower-upper pulleys and switch over to a 48 driving 53 pulley setup, but if we want to run a larger upper pulley during breakin, we'll need a longer belt.   I tried to put on a 59 tooth upper pulley (next size I had from 53) - won't work.   We'll need to determine what pulley combinations, overdrive and belt we'll need for the dyno.
Attached is a picture - kind of looking a bit 'Bad A$$' now isn't it!   8-)    I have a lot to do in a short time - going to be a thrash in the next few weeks.
Dale
Member of FlatCad Racing Team - 2011 - 2025
Goal:  Have fun, make friends, be safe - learn as much as possible, contribute when I can and hopefully see this beast of a Flathead Cadillac go over 200 mph!
BoredAndStroked
Here are a couple pictures of the head - you'll see how it is a 'clam shell' design:
maguromic
This engine makes my man parts tingle.  :cheers: Tony
Tony, Dale was just 'teasing' you!
Here's a few more!
Hard to believe - but Tony, I've finally seen something sexier than your avatars on these boards.
Buddy, Dale - That's ONE BEAUTIFUL ENGINE!
