Well,  I jsut spent the last two hours p-u-l-l-i-n-g the frt skin over the drivers area----YEAH---it is difficult to pull on---but it self aligns and looks like it will have virtually no GAPS-- one of my lousy welds popped while I was pulling it on with two ratchet straps.
This post s seems so trivial but the way the body jumped around once I cut it when Summner was here.  I have been very concerned that it might not align back up. No one else was around for me to celebrate with----so you guys are the victims!!!
Now I should be able to take the frame back out side and prime this thing then install the fuel bay skin PERMATELY and start final assemby and make this building a car LOOK like it.
38flattie
Thanks for the chat yesterday!
Post pics, post pics! We need to see this! :-D
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Likewise Buddy---
Doug Came over Tues. and he will runn the formula on the "Starship bridge" wind screeen and Francis brought the air intake by and we tried the fit an saw that it was what we are looking for he took it back to finish it up.  We hope to start priming it this weekend.  Al E. and Denton came by this morning for a vist and to check on progress.
brackets, brackets,  :-( body, body-- :-(--I am wanting to get to priming the frame and starting  AND get to final assemble SOMETHING
Tman
Final assembly is like a fine ale. Well worth the wait! :cheers:
You figure out the chute lanyard yet?
#830
TMAN   I  have built  "noodle" Bell cranks to try push or pull --- I am THINKING I am going to have the primary be a rod that pushes but the seconday is on the side I get out on so for clearance reasons I may pull---once I make a final decison I will try to do something that looks nicer.
Tman
I am just thinking a rod will be the smoothest way in mine. Slide rod forward if the air fails.
Frankie7799
Might just have to swing by this week on my day off and take a look at this bad boy in person
come on, come on---but only time and a few passes will tell if it is going to be bad
Frankie7799
Sparky, was good to meet you today and get to see my first LSR car up close. Not sure what I can help with but if you need a hand with something or when the time comes need a hand at El Mirage or Bonneville, Id love to help out.
Likewise Frankie
Well I was going to order my transition 45 deg  but they have stoped making them  they are NO longer in the exhasut business so I resorted to ordering some 7 deg. cones  from Cone engineering and some 45 deg 2.25 45 deg bends from Hooker they are on back order but they are 16 guage.  Thanks to Contrivance Eng. and my crusing the internet for WWII fighter inspriations the P-40s and Supermarine Spitfires for my exhaust noodle prompts.  Dr GAS used to offer 2.25" tubing to 1 5/8" x 3.5" 45 deg. transitions---no more.  Plan is to cut and modify the & deg 2" to 4"  cones to look similiar to those.
fredvance
Bill, Burns stainless has a ton of exhaust stuff, both stainless and regular steel. You might look at what they have, if you already haven't.
Tman
saltwheels262
stainless works is in Chagrin falls, Ohio.
they have a lot of parts and tech articles in their hard copy catalog.
I have never looked them up online.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
#839
Joey is back in town from his Alaska fishing adventure.
I was able to help a guy get his twin turbo blow through set up  ironed out---he had built the HAT with an inlet on either side of a circle and it didnt blow straight at each other---they we causing a very active tornado inside the hat--- a baffle on each side  at 90 deg to air flow stopped the vortex
