#810
Sumners handi work
kiwi belly tank
Well you lost me with that one Sparky & possibly a few others too I'd say. Looks like you had a spare wing tip? :? :?
naw  its a rat rod air cleaner---keeps the bugs rite outa ur teeth  :-D
kiwi belly tank
Good one mate! :cheers:
I won't say anything, I know it's really a secret weapon like the Ozzy winged keel. :roll:
Crosley
I'm just eggcited to read that Sum is working on a car.  :-D
Tony in AZ...
"If you find yourself in a ditch.... let up on the throttle"
Dr Goggles
good on ya trooper,lookin forward to seein ya all the same,champion effort to see you get this far so fast,is Sailor Sum comin?
#817
Well SpeedWeek sabitical is over  got back in the shop yesterday afternoon--worked on something simple---the push bar roller wheel---finally found what what I think will work---a caster wheel that has a 5/8" bolt for and axle and it has a coverd steel wheel  if we mash the "tire" off we still have the flat wheel will weld it today  I am going to try to finish the car(bracketts & frame from the bulk head back that we can roll it out side and paint the frame with our Rustolem spray paint that grinds off easy and touches up easy yesterday I also "noodled out" installing the weight bars I got from Saltiene Jim's YOW by the end of the day. That will make a total 400# mounted low in the bottowm of the car just in frt of the rear axel.
jeeze  I could not even add 140 + 160==300 not 400
Podunk
Sparkeee,
Grant wanted to know who the old guy on the far right of our room was.
                     Terry MouReR
Message for Sum...................I'm so glad you escaped the water.
Welcome back.
Ruth.....make him answer his e-mail. It may take a week but he has been missed.
Dave and John come over today  we have the Heavy metal tacked in and and started on the fuel hatch
jeezee  no wonder I sold trucks instead of body working on them---I   :? :-o at it  slowly making progress--- will be in the shop most of today  this body stuff has to get nailed down so that I can Rustolem Primer the frame  I have played with the cam locks enough to think I can do a passable job on attaching body panels---I I do not have the dicipline to take the time to do this fairly right  it will be all for nought..
SW verified something that PP told me a long time ago one night at the KOA.
Sparky,  You can spend Millions on research, design, & construction, to get the best possible shape; millions in the wind tunnel tweaking the shape, and it can be undone by 15 minutes sitting in the sun on the race course.
I think I am learning the hard way :oops:  why "tanks" are split in half lengthwise and mounted that way---One has to "deal" with it in ONLY two dimensions.  I didnt understand that when I started---the lesson is being reavealed  :-o  to me now as I try to mount and seal it.
John and I had a good day in the shop we cut some strips to help force the alingment into place ans one will do double duty.  It will be the lip the fuel acces door seals against.  John remembered that he had seen a HF planishing hammer some where---well  got it down put it together and tried it out--- we have lots to learn but it did smooth out what we had done with at body hammer over a piec of 3/8" arc
#824
Well  I spent the about 8 hrs between yesterday and today, doing what Marty could have done in 45 minutes. doing about 12 roset welds and welding in the strips that John and I made tues.  This is the first time I tried TIG doing this alum stuff.  I got a little better as I went along but they are horrible---they are on the inside and I am sure Marty will make me autograph this so no one will think that He or Joey did it.  lol
I will try the body alignment tomorrow.  I think it will be tight I just hope it aligns!!!
