The mention of shift lights brings back a bike I was teching a few years back.  It was a Brit guy, I remember, and when I asked him why he two shift lights on the bike he pointed to one of them - different color, different size - he said "That's one's a DON'T SHIFT ANY MORE!!" light.
You car guys might take something from those of us that don't have gear indicators so we know when we're in top gear.
Don't do it again light ---because if you punch the air shifter one too many times it goes  neutral   :roll:
If you max out your RPM in high gear, you are geared wrong!   :evil:
We started using a shift light after the 2012 SpeedWeek... getting Pork Pie to rev the motor high enough was a chore... he had to spend a lot of driving time looking at the the unstable needle on the tach.  Installed a shift light and the problem was solved at the World Finals.
Of course when the wheels break loose due to a rough course, the light will come on and make you shift a bit early... we still count shifts  :-o
Francis has found a gauge that can count  we may use it also  :-D
Marty has the 2.26 pinion and is removing the .022 so that we can shim it to where we want it and get the 8.5 pinion to mount in the 8.8 housing then we will start on re-tube part modifying the housing to the correct length and putting the 9" ford ends on it.
ggl205
Quote from: Stainless1 on May 01, 2017, 06:52:33 AM
At my age, I start loosing track after a two count.
Maybe that's why a little valve float isn't the worst possible thing, my "seat of pants" meter always tells me when to shift...
Hey Doc, most guys start to cringe a little when the motor passes 10000 RPM, sounds pretty wound out... you're sure the valves will float, tag and blow apart.... 'cept ya need to wind it another 3K before you shift.  It does have a rev limiter... and that keeps you from going much past 13K and floating the valves...
Sounds about the same as when you burn a valve... then you have to look at the tach and say shit! it ain't on the limiter.
If you want to really scare yourself... listen to one of those 600 motors that rev to 16000  :-o  :cheers:
Elmo Rodge
John, Ron Benham had a program to let him know when to pop the 'chute. Put 5 marbles in your mouth. Every time you pass a mile marker you either spit one out or swallow it. When you run out of marbles you hit the 'chute. I'm fairly certain that this could be tailored to fit your shifting needs.  :cheers:
Wayno
Quote from: Stainless1 on May 13, 2017, 06:18:55 PM
Sounds about the same as when you burn a valve... then you have to look at the tach and say Subaru! it ain't on the limiter.
I'm not talking about the new motor, our old one flatly refused to go past 6500... 10k is like talking with a straight face about the afterlife
And those Honda tachs have a bullf#&$ factor built in....
Oh boy is that so true about the Susuk's speedo's also--Russ and I sure found out about
Quote from: Dr Goggles on May 13, 2017, 10:48:07 PM
Quote from: SPARKY on May 14, 2017, 08:06:06 AM
Yes we saw that on the dyno with BJ Burkdoll's truck.... they are built to impress the rider... as is the speedo...
that is why we use the MoTec...  :-D Our old Tach has always had some instability above 10K... no matter the input... the MoTec shift light is accurate
Tangent:  In the late 50s my dad was sales manager at Electro-Voice, and EV once upon a time made tachometers that worked with an inductive pickup.  With each new tach came a little "tuning fork"-like device that was calibrated to wiggle just-so at a specific RPM - and so the tach could be calibrated.
I discovered, for instance, that the bushing bearings in the 47cc go kart engine (which was originally limited to 4,800 rpm) lived for a few weeks of regular 8k runs through the subdivision.  I also discovered what a seized bearing does...or doesn't do.
Hijack over.
Jon;
Electro-Voice made some really fine speakers. The "Patrician" was really awesome.
BTW, radar speed guns are also calibrated with a tuning fork.
