krusty
     Buddy - Does that biga** spoiler have some way to relieve the pressure buildup if the car spins? I have put a car with a similar spoiler in the A2 windtunnel BACKWARDS and it  developed some significant lift with the back end facing forward. (Think of going backwards towards Floating Mountain). Either hinged at the connection to the body or a couple of simple flaps in the spoiler surface (flaps are kept down by the air moving over them but open when it comes from below). Similar to the cowl (NOT roof) flaps on a NASCAR Cup car.     vic
     Edit: I went back and looked at the pics again. I don't think  it will generate as much lift as I saw on the car we had in the tunnel, which had much more surface area hanging behind the bodywork. Still best to be prepared, IMHO. The 325 TO ex-Dale Jr. Busch car spun last year and the spoiler ripped the deck lid off (still had the  NASCAR mandated tethers, though).
WZ JUNK
Quote from: krusty on April 09, 2013, 11:49:20 AM
Actually it may seperate from the car, if the car turns backwards.  In my opinion that would be better than it trying to lift the rear of the car.  I had that in mind when I designed the way the spoiler is fastened to the car.   It is attached  to hold a load from the top and the front but will tear away if the load is from behind.  We are in a gray area here but all you can do is go with what seems to be right.
Hopefully the big spill plates will act like rudders and keep it from spinning.
We are in the middle of a redo of the spoiler today.
Crew chief #974 B/BGCC 1953 Studebaker Past Bonneville record holder.
Additional braces are on, and the area between the spill plates and body are filled, per the rules.
Roseville Carl
It is still amazing to me on how this has developed from day one, a simple Cad flathead build, and where its going now, great job Guys!!!!!
"Keep Em Between the Whites"
Carl you are so right!! If this isn't the biggest case of "mission creep" I don't know what is!
And it is, and has been, so much fun to watch, thanks Buddy and crew!!
Quote from: Rex Schimmer on April 11, 2013, 07:50:46 AM
Reminds me of the guy that bought a bronze prop at a yardsale then built a ship around it!~
They just have that speed addiction thing... and that always leads to "project creep"  They just need to attend a couple of meetings and things will get better.... first meeting for addicts on the salt is in August....
Hi, my name is Stainless and I am a landspeed addict....
Hi, my name is Buddy and I am a landspeed addict....
Hi, my name is  (your name here) and I am a landspeed addict....
Haha! I'm not sure 12 steps will cure what we have!
Don has been busy perfecting the lifters. Dema signed off on them, so we are now ready to go to production!
From Don:
first pic-- oil grove and oil hole to hollow center
# 2  drilled the length of lifter to cross oil hole
# 3,4,5,6  crossed drilled one side only to feed roller bearings on wheel  I will plug weld non needed holes
# 7,8,9ect bored 1/2" diam hole x 1-1/2" deep in body made a top insert ( will change to a flanged insert ) to press in the body and tac weld at assy
also the flats are .040 deep on each side
...and a few more pics.
I don't think the #2 pencil makes a very good engine component but the rest of the stuff looks nice!
What hardness will the lifter bodies be heat-treated to? (I think you said they are 10xx mild steel?). Surface-smoothing before or after heat-treat?
pops29
  The materials we will use has changed -- Because of the mods to the lifters we now will use  8620  heat treated
pops29
  The heat treatment will go to 50-55 rc and ground finish
The cam is done, so I thought I'd share the cam info.
...a little more info.
