pops- thanks.
Any idea what the maximum negative acceleration is of those cam lobes?
Quote from: Jack Gifford on April 13, 2013, 10:37:38 PM
pops- thanks.
Jack,
I don't have that information. To be honest, I'm not knowledgeable enough to know what I'd use the information for!
So, what would I use the info for?
To calculate minimum required spring force for a particular combination of engine speed and valvetrain mass.
lsrjunkie
Nice bump stick Buddy! Those lifters are pretty trick as well! I may not have ole Hank in tow in August but I will darn sure be there to see this thing run!
Joe, if you're at the salt with no car, come hang out with us-we at least always have lots to drink! LOL!
Don just sent me this update-way to go, Don!
Small update for all.. I set up the heads and removed the o ring we were using ( .031 ) so we can run a larger wire ( .041 ) with a receiver grove in the block .
So- how do you cut those irregularly shaped O-ring (and receiver) grooves- CNC mill? If so- did you translate the shapes into a series of geometric segments (arcs, etc.)?
Roseville Carl
wizardry just plain wizardry, plus Dons a master.........
"Keep Em Between the Whites"
Geo
Quotewizardry just plain wizardry
There is a lot on this car that makes me think about the things I am doing. Are you going to run the engine on the engine dyno, chassis dyno or go straight to the salt?  Put me down for "over"!  :-D
Geo
We've got to call Dema and tell him to put some ink in his printer . . .
Roseville Carl
Carl, Don is finishing the final version of the lifters and blocks, and Kenny will hone the cylinders and install the cam bearings on Monday.
I scheduled the dyno with John Beck yesterday, and we will be there July 1-3rd.
Roseville Carl
Well Dodge thats good news will see ya then!!!!
Will bring some Hop Rod Ale too
Carl, it will be great to see you again!
John has been making great progress! He still has some final fitting and mods to make, but things are looking good!
He has the rear enclosures done on the front mods, but still has to cut some vents into them.
jo maoma
are the fenders a one off pieces or did you start with an "off the shelf" fender blank...
