Wow,  do I now have a better appreciation for resplining axles using old 9" Fords as cores  just because they have the right bolt circle and the right bearing does it mean they are "EASY"  the cores I found with 5x5 bolt patterns had HORRIBLE run out  spent several hours with a lathe geting them wihin usable spec's before we resplined them---but LEARNED A ton!!
This morning in Lubbock where I up some Irrigation pipe 7'  3" used .053 for pilots and a 9' piece of 6" .053 new drop for my Chute tubes---Bob Stroud says order now to beat the first of the year price increase!!!  All of these will be cut to length for pilot and mains as needed.
floydjer
Sparky, What are you using to spline the shafts ? Rota-Broach?  Indexing head ?  We have to know these things !  JB
Just saying...................at one shop I worked at we resplined quite a few Ford axles. It was a pretty simple operation but the problem came when the splines twisted off in the rear end under any sort of abuse, ie: racing. We ended up discontinuing the process and just using aftermarket axles which were available in any length and spline you wanted at what turned out to be a relatively reasonable price.
We were using an indexing head---the thing uses a hirizontal mill with air switches for shuttle and rotary signals  you are right after the fact we found out we can buy "blanks" for less than a $100.00  That will be the future plans.
#184
Woody is running his "evaluation" to see if it is worth the effort to try to raise the back of the car 1.5-2" so that we can stay with the 24.5 tires instead of going to the 28" tires for the rake.  We really need to stay with the smaller tires if we can for gearing reasons.  It is worth the wait and ensuing effort if there is a difference---
-"I think"  but as Saltfever says data beats an opinion!!!  :-D :-D  waiting for Woody---we should know this week!  :cheers:
38flattie
Woody's stuff is pretty neat. I'm curious to see what his conclusions are.
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
#186
here's to "that ol'e lady" Ms. Fletcher
http://www.youtube.com/watch?v=76LbvnoIDkE
Woody is trying to change the name of the new car----he keeps refering to it as the Thud Spud  :roll:
#188
Small strange little world we live in!
Last night at a meeting a man came up to me and said, " I am Capt. Russ Whittenburg,  I met your wife the other night at the PotLuck and she said you race.  I use to club  race what kind of racing do you do?  I said LSR. What is LSR?  On the B'ville salt flats.  What kind of car?  Lakester. What is that?  One of those long skinny cars with the tires on the outside.  I want to see it.  Well I sold the old car I am building a new one out of a ferry tank out of a F105B.
And he says " When I was a young pup, fighter jockey in Germany I use to chase Thunderchiefs, those things sure couldn't turn much but they were plenty fast going straight, I couldn't catch them!
We called them Thuds.
Well maybe Woody is on to something, I dream about building something that can't be "caught".
Thud Spud does have a certain ring to it.  lol
WOODY@DDLLC
"Thud Spud does have a certain ring to it.  lol"
Me thinks it sounds better than Sparky's Tater!  :-D
Coping  flat angle diagianols are a B----
Tman
Quote from: SPARKY on November 18, 2011, 05:27:35 PM
Tell me about it! Working on that myself!
Well if all goes well I should be able to know if I will fit in this thing Sunday night.  I put i tacked in the diags on the left side yesterday.  Should get in the right side today, and planning on fitting and tacking the 1/4 plate that will be the seat bottom Sunday, and tacking a 6" X12" strap to simulate the fire wall for the back of the helment.  but when I climbed in last night---I think we will be going on a diet or back to biengineering the diagonals---GOD forbid we have to go to a designated driver :-o
Elmo Rodge
Quote from: Tman on November 19, 2011, 06:55:36 AM
That's where the aforementioned PVC tubing comes in handy. Sometimes I even use telescoping tubing. That way I can hack away indiscriminately and just slide the ends out to fit. Again, this just gives me a good visual reference so I don't waste a lot of the more expensive stuff.  :roll: Wayno
