#630
Great day in the shop!!!!
Freaky failure---unbelievable good luck!!
This is the rear stud that held the plate down over the camshaft the the dam thing was floating around but nothing fell in to the cam gallery--when we turned the ting over on the motor stand the washer fell through the push rod opening in the head an down in to the valve cover ---when we rotated it back up it fell and his the valve cover with a light tink---we all looked at each other---I roated it back upside down and it made another small sound--pulled thevalve cover and found a small washer---well that scared the bejesus out of us  we knew we had to pull the intake and see what happened!!  no damage---we got darn lucky  I now know why so many folks pull stuff apart and CHECK EVERYTHING after a dyno run!!!
bucketlist
Quote from: manta22 on June 09, 2012, 10:46:34 PM
Stainless;
"It has never loosened in the 12 years it has been in that configuration..."
Maybe the Bonneville salt will corrode it in place  :-)
I'd still put a pin in there.
...as they said aboard the Hindenburg, "We never had that problem before...."
Regards,  Neil  Tucson, AZ
Reminds me of the words of Carroll Smith in "Preparing to Win". He says you don't need to safety-wire everything on the race car, just those things you don't want to have fall off.
Nostalgia isn't what it used to be.
#633
what great luck---if that little washer handn't fallen and made a sound we would not have known about the failuer of the stud and we looking for the broken part!!!!!--found it wedged in beside a push rod left a minor minor scratch on one of the tapered push rods---lucky lucky lucky
Dr Goggles
Bill, we're hanging on every word.....
#635
update:  John cme over early and stayed to 3:30  what a great help this guy is  Marty came over and stayed till almost 5--Andy droped by at 6:00 and we worked on the chute tubes and "bingengineered" till 8:00
a   Cut the chute tubes and stuck them in there
b  lots of work on the sump tank today
c  weld in-- cooling transfer pump
d  the brakes got some work yesterday and today
Got the front motor plate mostly done need the tabs and mounting bolt holes drilled and mounted!
Eng is in the car---not locked down ---almost---brackets brackets---foot throttle-- barckets brackets this stuff drives one mad some times---found out it goes better with beer---the charity beer of the day is Modello especial---my buddy Goose bought an 18 pack and had only had two disapper in 2 months---there have been 10 disappear in 5 days in the shop between Andy and I---charity beer tastes really swell be cause the price is sooo good :cheers: :cheers: :cheers:
Tman
You guys drink too slow but Modelle is ok!
#638
us old guys have weak systems--some of us no longer are up to FULL strength beer 3 = a 6 pack of lites lol
Captthundarr
I am I am  :cry:---but not easily impressed  :roll:
Captthundarr
Well I am. like the buid. been following it for a while. :cheers:
bvillercr
Watching a military documentary on your 105 Thud, good stuff. :cheers:
link or what to watch for?  :-P
bvillercr
It was on the military channel, according to the documentary there were 78 B's made and the rest were mostly D's which was an extended nose.  The later 105 models were upgraded electronics.  800 and something made half of them shot down in Nam.  It was a good watch!!
