jl222
Quote from: SPARKY on January 13, 2012, 08:06:20 PM
stuff   :-o sticking out in the slip stream is why some go slow  :cry:
  Fot those that want to go fast check out the Roklister [sp] Bennett and then Seth Hammond lakster build
around 40 yrs ago :-P
dw230
I begged Rich Manchen to put the exhaust under the rear end when we built the lakester. Didn't happen, his theory was that a blown engine will over come all.
I used to tell my Mom "The Lord helps them that helps themselves, and I am trying to help him as much as I can".
  I do not have a lot of HP so I am trying to eliminate as much DRAG as I can no mater WHERE it is!!
Only time will tell if I am on the right track!  If I go faster, Then I will come up with the $ for better heads ect. ect. --- I know where to find another 300HP NA on GAS!
dw230
Sparky,
Look to 77, put the exhaust under/within the body.
Just sayin'
robfrey
We had the same brake issue because of our wheel pants. We will be using a brake kit from Coleman on our liner. They are floating hubs and made forIMCA modifieds. They are pretty compact and fairly inexpensive. If you are interested, I can do a cad layout for you to see if they fit within the wheel an what offset you would need.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Thanks for your offer Rob I just need to find some brake shoes---I am happy with my choice for many other reasons  no drag and no worry about rusted stuck brakes are the two main ones!
kiwi belly tank
Looks like you're sticking with drum brakes so lets not try to re-engineer your car for you. :-D
I Utah & Spudaho we have Page Brake that do brake reman stuff but any quality brake reman company should be able to help you. They do a lining that is designed to survive excessive use in light trucks.
If you end up with a bonded brake lining, drill & rivet it as well, the excesive heat build up will want to delaminate them. Cut heat breaks in them, three seperate sections on the lining with 1/4" gap between them to help release the heat. Use the thickest drums you can find & drill them just like you would a disc.
Anybody remember "brake fade" ??
Back in the early 70's we ran a 4 wheel drum brake Group "E" Chrysler Pacer (Ozzy Dodge Dart-ish) in the Bensen & Hedges 500 in NZ. We learned how to make them work but we still changed them every 100 miles or so.
Racing drum brakes is probably a lost art by now.
gas pumper
Quote from: SPARKY on January 14, 2012, 03:29:55 AM
and you can go with a nice short tire and 15" wheel with the drums.
Our experience this year on the 608 was that the big ass Brembos were more trouble than they are worth to us. And they just barely fit in the 18" wheel.
We should be going back to nice old Ford drums too for 2012. I'm pretty sure we will not do anything special as far as linings go. Whatever Bob has up in the attic will be fine with us.
Frank
Crew for 608 AA/GL.
Crew for The Flying Seven, 7207, XO/GCT, V4/FCT Loring.
Crew Chief: 7207 XO/PP.
jl222
Quote from: dw230 on January 13, 2012, 09:02:43 PM
Sparky,
Just sayin'
And the teardrop shaped axel fairings 8-)
Ron Gibson
  Back in the 50's & 60's, Ford and Chevy 11"ers used the same brake linings. 62, 63 & 64 Chevy police and taxis had semi metallic brakes with it optional on other models. Maybe find a set of them??? Even used, if not worn out, would probably work for you.
 I don't think it would be that hard to make your own.:-D   You can buy metallic brake blocks for big trucks and cut/reshape to fit your shoes.
There is a site (Industrial Brake and clutch Exchange) that might be able to help you. They say they do classic car parts.
I have a semi metallic high speed reduction device. It's called a "ROADSTER".
Ron
38flattie
Sparky, I'm going to throw this out, and let you shoot it down! Yes, I did hear you that you just needed brake shoes!
What about an inner disc brake system like the Jaguar has? I've seen a lot of QC setups done like this.  As your diff is covered, of you have the room, it might be worth looking into.
Then again, maybe not!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
While that may or may not work for Sparky it's certainly an interesting idea. It would require the use of a sprint car type live axle and then the support for that could be a single strut rather than the bird cage normally used in a sprinter. This could get other minds churning. The forum works again! :cheers: :cheers: :cheers:
38flattie
I can certainly see some benifits, for some vehicles.
I still have most of the parts needed..... :-D
I think I finally found someone (Patterson I think) in CA that offer all types of RACING brake shoes  I will call them Monday or Tuesday.  Search racing brake shoes
Dynoroom
Quote from: dw230 on January 13, 2012, 08:40:29 PM
I've heard that quote some where else before........... Maybe it was Fast Freddie.......... or Dave Davidson?
