Tman
Sparky, hard to tell but what thickness is that plating for the "drivers box"?
Jon
That's some serious metalwork Sparky.
You going closed or open tail?
jon
Underhouse Engineering
#453
mostly open, although above and below the chute tubes I MAY close and fair to a pointy end
The shape we are using generated about 200# lift at 300 so we are going to make the fairings so that they will resopnd to changing the angle of attack; but we also wanted to make it as resistant to torsional twisting as possible with a fairly narrow frame---hence the very heavy plating on 3 sides up front.  Also Mr. Burkland encouraged me to keep the pod small so that the "peas" couldn't rattle around much in the event of "happenings"..  someday depending on health and ect  we wish to add a little mechanically induced decrease in Density Altitude---aka hair driers
#454
Friday Andy and I picked up the new front "shoes" for the baby at Nate Jones's Cowboy Tire Co.  Wow has the price of "POKER" gone up---it seems like one must pay to play  lol
We will be taking as good a care of thes things to make them LAST  I only bought 2 even though I had Marsh make me 3 wheels---the spare will have to wait!!  We have a car to finish and the body I am sure will take some serious "coin" to finish!!  Going to the Gear Grinders annual get-to-gather!!
Captthundarr
Lokin Good Sparky, Keep the info come'n. beyween you guys and the other fine (?) folks here my library is filling up. :-D
We had a good day in the shop---computer down---no picts--
mounted the frt axle
modified the SpeedWay steering lower arms to work on the upper holes and modified the hubs by cutting off the lower strg. arms  we will soon have the frt axle together---we may soon have a roller :roll:
#457
here they are!  geeze you would think that as many of these as I've done I would be able to get it right the first time ..
Note:  the Axle is only removeable side ways after the 4 1/2" bolts are removed; it is trapped vertically against the axle above by the tubing protuding through the "Battery Basher" and the 3/8" mounting bracket at the bottom.
38flattie
Based on past success, and the quality of the build, this will be one to see! :cheers:
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
We had a pretty good day yesterday---Welded in the bulkhead --we will now be able to start "brackett racing" the fuel tank, radiator in a box, and the dry sump tank fire bottles.
I normalized with a rose bud all the joints in the eng bay especially the one we are going to put the removable "joints" in---picts to follow
Skip called andwill be in town today and Thurs. morning--- we should be able to break bread together
Tman
Sparky, I am working on my front axle right now as well, are you making any provision to change caster? And what caster are you shooting for?
6 deg  not really any provision for caster change other than cutting the 10 HARD spot welds that hold the axle to the bracketts  could be done by shimming the flat bracket I guess!!  The only reason I but 6 deg     was  I guess some is expected
#462
Yesterday;
you can see the heat lines from the normalizing the joints with a rose bud tip---when we cut the tube it stayed straight!!
We will now install the connectors in the other two tubes we are putting them in!!
#463
hubs:
  you can see where we had to grind the ridge out of the back of the spindle so that it would clear the Speedway axle--
-also note where we cut the lower steering arm off and we will  the install the Speedway arms that we have modified to mount on top so that we can get the steering rods in the wind shadow of the frt axle!!
will post pictures of the modified strg. arms soon
Jon
Looking Good Sparky.
For your removable joints did you normalize the tube, cut and fit one joiner, normalize the tube again and cut and fit the second joiner?
Thanks
jon
