Bill;
Your tie-rod looks just fine; you cut the ends at a diagonal so the stress will not be concentrated at one point and added rosettes for good measure. Don't worry about it.
Sparky, the design looks to be in line with generally accepted practice and I wouldn't worry about that.
Check my PM for further suggestions.
Tman
No worky for me. Early Ford hubs do not have enough meat for the knurl depth. Thanks anyway, always love beer trades.
will up date later
Anyone have a recomendation as to a sprint car strg quickener that seems to work well in reverse---this puppy is QUICK  :roll:
Skip Pipes
Sparky,
Look at the 2-1 HOWE unit. It's what I put in my car.
Here is a link to Speedway.
http://www.speedwaymotors.com/Howe-Steering-Quickeners,24447.html
The 7.5 axle is getting it's gears this week!
Skip
Skip's Garage
Dr Goggles
Quote from: SPARKY on April 29, 2012, 06:49:21 PM
Bite the bullet....get some longer steering arms, you could mock some up to work out how much longer.....those ones look a bit flimsy anyway :-D :-D
robfrey
I used the same quickener in our liner.
Great minds think alike? Lol!
Those steering rods should be fine.
The silicon bronze filler was probably a good idea as the lower temps will have less effect on components than welding.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Jon
Do you have enough room for duplex chain and sprockets Sparky?
That way you can set the ratio that you want rather than what you get, you can also fine tune the ratio layer if you need.
Cheers
jon
Underhouse Engineering
Well I was up in the middle of the nignt so I went to the shop to set up the mill to drill the holes for the wheel studs.  drilled my test holes in a piece of 3/8 with the 9/16---probabaly will not work, not enough knurl bite --off to the shop today to buy the correct drill for the original studs..
Thanks for all of your feed back on the tie rods--this is what so great about this site there are folks that will usually end up on both sides and that gives one a HEADS up to rethink, reavaluate, and the one gets to make a "englightend" decision  lol  seriously thanks for the pros and cons  I feel confortable about our decision and especially about Marty skills who did the actual welding on this part!!
#520
Sparky,
I used the Howe quickner box on my little modified street roadster, mounted it  backward to slow the steering down and probably have 5000 miles on it with no trouble.  I like the fact that you are putting the steering rod in the aero "shadow" of the front axle are you planning to do any other type of streamlining of the front axle and steering rod?
Rex,  eventually we will and it may happen this year---but the number one objective is get a car DOWN the course, and FEEL that chute as DF talked about in the flick narated by Dr. G
Podunk
One way to eliminate concern about the welds on tie rods is to eliminate welds. How about 4140 quenched & tempered round bar. EZ to do. Call me.
                               Terry
Terry,  Thanks for your offer---Others are concerned---AEN says "What me worry".
Another good day in the shop  picts and naration to follow!!
