Rex;
1/2" wheel studs are kind of small, aren't they?
Tman
Quote from: Rex Schimmer on April 27, 2012, 01:56:28 PM
Just a note: 17/32 dia drill is not an uncommon drill size. It happens to be the recommended drill size for clearance for a 1/2 inch diameter bolt. I know most of us use a 1/2 inch drill for a 1/2 inch bolt but if your drill press is like mine the hole comes out .010 inch larger so the 1/2 inch bolt goes through.
We must have the same press!? :-D
#497
I ordered some of those Speedway 5/8  before I was smart enought to check how a 5/8 fit my wheels---not   :-o  only as a last resort will I mangle my Taylor Mades
Tman
Quote from: SPARKY on April 27, 2012, 03:07:33 PM
I ordered some of those Speedway 5/8  before I was smart enought to check how a 5/8 fity my wheels---not   :-o  only as a last resort will I mangle my Taylor Mades
I may be able to take those off your hands, let me look tonight
if they do--- payable in beer at the Salt Talks!!!
Bill;
In circle track racing, 5/8" wheel studs are standard. Virtually all stock car wheels are made to fit 5/8" studs, usually 5 on a 5" circle.
Tman
Sparky, I think we have a deal. PM me your addy and I will send shippings costs! :cheers:
Well I had a great 1 1/2 hours ---after dancing around dealing with my steering tie rods  I went to the shop this morning got out the cut off wheel whacked them--whacked the tubing I bought into 6.5 inches went to the lathe to counter bore the ends to the steeering rod sizes .500 on one end and .45 on the other wire brushed the paint off  now I have to drill the 6 small holes for the rosette welds on each tube and walla  the wheels  will turn when I turn the strg wheel--- :-D
shoulder pads
tie rods
Kiwi Paul
Thought about Magnafluxing those tie rods Sparky? I`d do it if it were me, and I weld up Cars and stuff for a living........just saying.... :cheers: :cheers:
#505
What should I look for :?
I thought that magfluxing identified cracks?  These are a mild steel dom sleeves that are cut at a diag.on both ends, tig welded on the diag cut ends, and has 2 rosetts on the 1.75' insert that was a mild interference fit and the other has a 2.5" insert overlap with 3 rosettes, the weld filler was silicone bronze.  These extensions only have to function in tension and compresion.
What am I missing??--- I am not trying to be a WA!  The only way that this process could have been improved on would be to gas weld it, instead of tig it with the info that I posses.
Coaching Comments please!!!
BEER BAIT   :-D :cheers:   :cheers:
38flattie
#507
I think he's saying to mag them for cracks/micro cracks. When we weld on our derricks, we X-ray the welds the first time, then have to mag them to get re-certifications. On non-load bearing stuff, we are required to mag new welds.
I think having your welds magged would be overkill, but that's JMHO. It sure wouldn't hurt, of course, to be positive they're perfect, as that is a criticle part!
Looks great!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Tman
Hey, i have the same caliper! I will check tonight but I think those are the ones I need. At the office right now.
kiwi belly tank
Cousin Paul is right Sparky, I'm looking sideways at that thing too. It looks like you wacked off a stock tie rod & welded a tube in it. Irrelevant to the quality of your welds, the weak points are at the weld on the ends.
It might have been better to machine up a screw on sleave to extend it.
