#570
Wayno,  Like wise---it was good to meet Buddy for the first time---neat, neat guy!
http://www.youtube.com/watch?v=76LbvnoIDkE
#571
Back in the shop and started on verifying final alignment before welding in the trans mounts and finishing the front motorplate. I have already found one mismatch the vertical tubes at the rear axle are not centered on the lower frame rails.  This is off by about 3/32 and should easily be adjusted when we hang body panels.
PJ asked that I post a shot of the trans. & possible future turbo bay with its weird bracing--once I get the headers figured out this bay will be subject to future "additions"
I will be the first to say  I really do not know exactly the final version of this area will look.
52514 shows 2 of the drivers side rails out to make it possible to take the eng. in and out!!
Captthundarr
Keep banging away Sparky been following for awhile. :cheers:
Frank
Thanks Frank,
Had a pretty good day in the shop
1. got the tranny mount in
2. got the water tank base mount in
3. Andy came over and finished the brakes
4. scored a used AFCO 2:1 steering quickner off ebay at less than 1/2 price
5 got most of the lines drawn on the frt motor plate so that I can cut it out
VI got the paper work done so that we have another PC in my Paradise Park Precinct to join in the FIGHT!!
It's hard to believe what looks so roomy now is going to be a really tight fit for everything but I fully understand what you're up against. I'll continue to monitor the build and continue to comment when I think I may be able to contribute. Your build continues to look good.  :cheers: :cheers: :cheers:
I enjoyed the conversation the other day Bill.
Tight fit  :-o ---lol  I think  :-P  I am going to have to leave the flat washer off to keep the mounting bolt from hitting the lower skin
3 steps forward 2 steps back  ordering parts--making brackets-- sending parts back to get changes made---racer stuff!! cutting grinding---nothing that stands out---
jdincau
Quote from: SPARKY on May 31, 2012, 07:32:12 PM
3 steps forward 2 steps back  ordering parts---- sending parts back to get changes made---
A pal of mine has a quote regarding speed equipment and the fitting thereof;
"It's just a bolt on accessory"
Buickguy3
  Sparky,
    I always used to like the bolt on speed parts that you got in the 50's from J.C. Whitney. The last line was always:"Some modification required". Followed by:" Not returnable if modified". Keep plugging along, it's looking good.
                   [America]
#579
Geeze  they just don't make these " bolt on parts"  the way they used to  spent the last day changing out my dry sump pan form the deep drag race one to the shallow one---guess what---they put two of the pick up tubes under the rods and not under the mains and they HIT!!  I will contact the manufacture Monday and see if they will make it right---
Brackett racing at its finest:
Water pump bracket by the rear axle
Fire bottle actuator knobs brackets each side of driver
Eng Fire bottle mounted over the radiator in the box
Shift lever built and mounted---not finalized
Fuel shut off cable mounting ---"noodled"
nap
last 1/3 of Nascar race  :cheers:
Great news John at Aviaid is going to furnish me with a new pan --I pay the freight both ways ---seems like I must have a NOS as he had changed the pickup tubes several years ago when everyone started putting longer and longer strokes in these things what would work with a 4" stroke will not work with a 4.25
Ya could have just noched the rods...  :roll:
We still like to see pictures of "not much going on regular stuff" digital film is cheap
#3 rod notcher  :-D
#584
SPECIAL  EDITION  :wink: for SS#1
Jhon came over early and stayed to 3:30  we bent some lower frame rails for one of his projects--which will be neat and I look forward to following it
He installed the vertical fire bottles and drilled the holes in the fire wall for the cables and we worked on lots of other small little things
