Well I first drilled them in 2 bolt holes  so that I could bolt/clamp the 3 plates together---aligned them as best as I could--then milled the two locating 5/8" with an end mill---pushed in my 5/8" dowels( they were a loose slip fit) then end milled all of the 3/8" bolt holes---
In the am will bolt them all together and sand all three to where the will clear the flex plate starter ring gear----then bolt up a trans an see how it goes
Larry Pater, a LSR MC guy from the Chicago area and his buddy Doug who lives here in the valley came by for a great 2 hour "get to know you/bench racing session"  good times  :cheers:
Well , we got'r done  guess what the trans locating pins are not symetrical---don't ask me how I know
I now have them bolted together and will finish shaping them so they will be interchangeable
also from my researching the LS engines apparently they duplicated the oil passage of the front to the block on the rear ----so here is my efforts
also I will need to restrict the lifter oil by bushing the lifter galley from the 9/16 to 7/16"  I will research this some more but I bet it is only on the one that doesn't feed the mains---this block does not have priority oiling for the mains---
Then to the machine shop to get the block cleaned, trued, decked piston, squirters installed so that we can order pistons and bore it.
hopefully will get the mid plate finished today so that I can use them to offset punch the missing LS trans. bolt hole.
I am sure that a lot of this stuff I am JUST being paranoid about but the "sig line" at the bottom of Fordboy's post "about the attention to the little things" just keep ringing through my head.
Quote from: SPARKY on March 12, 2015, 06:14:14 AM
Sparky,
Thanks for the reference.
I'm a bit paranoid too.
But I can tell you ONE TRUE THING about details . . . .
I'd rather be a bit paranoid, than be the teensiest bit stupid or lazy . . . .  that, bites you in the a$$, EVERY TIME.
I've only been to the salt once, but I've been to countless race tracks over the decades, and guess what:
Nobody WANTS to be the guy with the stupid problem, but those problems occur because nobody bothered to check some small, seemingly insignificant detail.
Why?    Because everybody KNEW it would be OK.     OOPS . . . . .
Run time/Race time should be just that, because so little is available.    It shouldn't be time to try and fix stupid sh**.
Bottom line is:  Somebody needs to check.   Everything.
Quote from: fordboy628 on March 12, 2015, 02:00:16 PM... than be the teensiest bit stupid...
Hey! You're talkin' to an awful lot of us folks!
4-barrel Mike
Stupid sounds so harsh.  For myself, I prefer woefully ignorant.   :mrgreen:
Quote from: Jack Gifford on March 12, 2015, 11:23:55 PM
OOOPS!!
Sorry Jack.    I was mainly talkin' about myself there . . . . .
F/B
Quote from: 4-barrel Mike on March 13, 2015, 06:45:49 AM
Stupid . . . . .   woefully ignorant . . . . .  meathead . . . . .  oafbrained . . . . . etc . . . . .
Pretty sure I don't like any of them.
F/B
Frankie7799
I was under the assumption that an LS block and an older SBC/BBC had the same bolt pattern where the trans and engine mate up. Only a spacer was needed in the back of an LS crank for an older TH or PG input shaft to ride in it? Is this not the case Sparky?
redhotracing
Quote from: Frankie7799 on March 13, 2015, 02:45:48 PM
There's an extra bolt hole at 12 o'clock, but other than that, it's a direct mate up. We use a McLeod bellhousing specific to our drivetrain (LS -> Jerico)
and it's worked really well the past 5 years. My brother has an LS with a TH400 behind it, he uses a spacer to mate things up.
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Frankie7799
Quote from: redhotracing on March 14, 2015, 06:27:13 AMThere's an extra bolt hole at 12 o'clock, but other than that, it's a direct mate up. We use a McLeod bellhousing specific to our drivetrain (LS -> Jerico)
Ah, thanks for the clarification  :cheers:
Sorta , all of the above:
---- the LS block does not have all of the holes drilled and tapped
early 6.0 cranks do not need the spacer
back of block
Frankie7799
Yep, I see the problem now. Thanks for the clarification Sparky
