Quote from: Stainless1 on January 12, 2012, 07:02:18 AM
Quote from: kiwi belly tank on January 11, 2012, 07:37:00 PM
I hear you on the head & neck thing Sparky, I'm in the same boat. 2" sideways, 1" up, 0" back & helmet in chest. Even if my head fell off, it couldn't get out of there. I'm going to use DJ's set-up, thats the only way I could get in the car & then see out once I get there. I also have swing up steering.
Sparky and Sid, we use the DJ, same position as you, lying down, chin on chest, 1 inch or less front, back and sides.  Yep you touch the sfi roll bar padding and it uncages your eyeballs.  I guess I would be interested in seeing what the ISP padding is and if it is legal for SCTA.  Anything that would let you touch and not translate the vibration would be a huge improvement.
Quote from: jl222 on January 11, 2012, 08:42:21 PM
  Kiwi...DJ's helmet straps don't have a quick release, so helmet has to stay on untill someone can release the straps.
  This restricks movement on exit.
  Wish I had know before buying :roll:
I guess we haven't had that problem with the DJ, it is the least restrictive and flexible use unit out there.  I guess in the sit up position the straps are shorter, but when your driving position has your chin on you chest the straps are loose enough to not restrict movement after you sit up.  Releasing the chest strap should loosen the restraints.  We didn't get the opportunity to use it "real world" in the liner yet but will be doing a bunch of garage practice before Speedweek.  Yes, that means we haven't had the time to practice exit with it in the liner, but we had absolutely no issues with it in the Bockscar
Stainless, Speed Demon and many other cars are using the ISP padding.
Pete,  from my experience we should for sure be able to warm them up at B'ville and ElM
I am open to sugestions on who might make something almost as good!
gearheadeh
#287
Quote from: Peter Jack on January 12, 2012, 06:17:21 PM
Why sintered iron Sparky? We ran a Corvette special during the sixties with sintered iron linings in the drums and as I remember they were all over the place until they got well warmed up. This isn't a characteristic that I'd like in a fast Bonneville car. I'm sure that one of the performance brake lining companies could come up with something that would cause less excitement on shutdown and be at least as effective. The sintered iron also has a real appetite for cast iron drums. You'll be replacing the drums regularly if the system works out.
I have experience along those lines as well, the linings were only worn down about 1/3 of original when the drums were way beyond max size. They both started off as new together. BUT, did it ever make a difference in stopping power   :-o
That stopping power is what I am trying to increase---I have tried a stop from 225 brakes only at B'Ville  do not wish to repeat that at ElM.  :-o
Sparky, Why are you even considering drum brakes?? Thats dinosaur stuff!!
Quote from: SPARKY on January 13, 2012, 06:18:29 AM
   With rear wheel brakes only didn't the tires just lock up and slide?
   My cousin Ed had a solid suspension Stude and in the old days [when warm up passes in other parts of El Mirage were allowed] came back and said '' I have no brakes!!' he had brakes, the tires were just sliding.
  Same thing on acceleration when sold and fuel hemi installed, couldn't touch the throttle with out wheelspin.
Modern discs with modern linings are going to be safer and give you better performance. There are several manufacturers that could give you what ever you need. I'd stay away from the sintered iron.
desotoman
Quote from: jl222 on January 13, 2012, 09:21:29 AM
As far as acceleration goes your Cousin Ed must not have had the car set up right. These pictures are of the weak link of a car that ran at El Mirage with a solid mounted rearend, and 3000 HP. My point is some people's combinations work others don't, more than one way to make things work.
  Tom...Ed's stude was a 25% setback D BFALT- A BFALT when Fogie had it and yea could have added a ton or 2 more than it had to the rear to hook up. What car did that shaft come out of? Did the same at El Mirage with our Doug Nash 2 speed input shaft before changing to an Owens with bigger shaft.
  Sparky...have you considered front brakes like those required now on Funny Cars?
There's lots of ways to put discs on your rear, you can do it with factory stuff from the junk yard & make some caliper brackets or just buy a kit & live on soup for a month like I do. Theres lots of ex-roundy round stuff on ebay to be had cheap & you can get good pads that won't go up in smoke when you're still on them at the 7.
Or try this for size.
http://www.ebay.com/itm/Aerospace-Rear-Drag-Disc-Brakes-Big-Bearing-Ford-Old-/230317330679?hash=item359ffb90f7&item=230317330679&pt=Race_Car_Parts&vxp=mtr
Drum brakes, thats why they have "run away truck ramps" on the freeways.
dw230
stuff   :-o sticking out in the slip stream is why some go slow  :cry:
Positive offset on the wheels so everything is behind the Moons.
